Electric Fan 101: Push Through Straps Warning
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
When you put an electric fan on your radiator, make sure you don't use the black plastic pull through ties. Over time they can cut their way through your radiator and cause a big leak and a bad temperature spike. Just food for thought. My friend and I have both had this happen. It almost cost me another radiator but luckily it was waranteed at Advance. It could have cost me my motor. My fan is much larger and the straps cut through the radiator more quickly (6 months) than my friends because he had smaller Autozone fan:
Not mine but this is what I'm talking about:
Instead, use aluminum strapping. You can buy it at Home Depot and hack through it with a hack saw in a matter of seconds. Just cut, drill and attach to the top/bottom of the radiator. :nice:
Here's my top straps:
Yeah i've often wondered about that happening but so far so good for me. I'll probably look into the straps though, nice tip. I love any excuse to go to the hardware store :D
That, my friend, is da ****zle!
I probably need to get adventurous (and responsible) sometime this summer and ditch my poke-through plastic fasteners, too, before I wind up killing my 3-core. Sure, I've got the same Autozone warranty n' all that, but I just don't wanna end up on a roadside with coolant everywhere, especially when temps this year are going to be over 120* in the summer...
Joe, I'm LOVIN the overflow idea. :nice:
Can you think of a way to have a site glass or something along those lines? It might be too Rube Goldbergish to drill a couple holes in the side of the PVC and run a clear section of tubing external to the housing.......... but that was the best way I can think of.
What's your lid situation like? I would like to mimic your idea on the space impaired '94.
I have considered that, and it would be a good idea. The stopper or cap for the PVC is a regular PVC plug with a wing nut on it. Tighten the wing nut and you have your cap.
attachment.php
Yes, the plastic fan and cooler mounting straps will put holes in the radiator. Been there, done that, got the t-shirt.
I have used lots of straps and brackets since then, including the 3 wire tie system on my 82. It's held the fan for 4 years now. Easy to remove and reinstall, with cutting pliers.
Have to say thanks for the heads up strype. I bracketed mine due to this thread so that I didn't fall victim to a leaky radiator. I used pretty stout aluminum bar stock and heated/bent it to fit. Works well and the fan ain't movin an inch.
As long as you have the fan bolted to the top of the radiator like the stock shroud then the pull through ties are fine.
All the weight of the fan cant be supported by just the fins...
I use the pull through ties just to keep the fan from hitting the pulleys.
That's exactly how I had it... So I put 2 more aluminum pieces at the bottom. No they suck.
I took Joe's great idea and bastardized it a bit to accomodate the space I have available.
I was able to accomodate the low level sensor which is nice because of the very limited volume in this new bottle (mine, not Joe's).
FWIW, the stock 94-95 bottle holds 7 cups (cold coolant full mark) and 9 cups (hot coolant full mark). I'm going to be lucky if I can hold a quart in the new overflow, which concerns me a little bit. We will have to wait and see how it goes.
This will fit down to the side of the radiator on the 94, whereas the stocker sits in front of the cooling fan, which is almost touching the water pump pulley. It will be really nice if this actually works.
This isn't finished yet, so overlook the unpainted top edge, etc. If anyone sees any flaws or has constructive criticism, I'm all ears.
JR's site hosting seems to have been acting up lately. It comes and goes I think. I tried to compare what I did to Joe's stuff earlier but couldn't. :(
The guy running the photo posting site is evidently a Russian, since the site is available in Russian and English. I think he may have slipped and fell on his vodka bottle...
:rlaugh:
I think St Patrick's Day can be a week-long celebration in some parts :D
The less Irish one is, the more celebrating and making-up for lost years one must do.
