Electrical Electric Fan Choices
it may or may not already have a diode to dampen the electrical surge. Adding one is cheap insurance - less than $2 and not hard to do.
So Radio Shack unfortunately didn't have the 1N4003 in stock, but they had the 1N4004, so I picked up a pack of two.
Will the 1N4004 work for this application?
It looks like the clear difference between the two is PV. Here are the specs:
- 1N4003: 30A surge; Peak Inverse Voltage (PV)=200
- 1N4004: 30A surge; Peak Inverse Voltage (PV)=400
The 1N4004 also includes specs for If (1A Max) and Vf (1.1V@1A), but I can't find that info on the 1N4003.
Thanks!:flag:
Thanks!:flag:
It will work OK.
Increasing the voltage rating is OK, decreasing the voltage rating isn't a good idea.
Reactions: DuderMcMerican
I just wired a contour fan in my car. Drilled the thermostat housing to use a BMW low and high speed switch. Used 2 relays for the fans.
Unfortunately, I don't need it because I'm going with MS, too.
I'm in southern Maryland about 45mins from 495 and route 5.
