im getting an electric fan its a flex lite do i need to run a bigger alt or will my stock one be ok not sure how many amps it will draw
Black 93 Fox said:Your stock one should be fine as long as you dont have a big stereo system or anything like that. I have the stock alt with underdrives and electric fan and have no problem.
, cant blame it though, i'm constantly starting/turning off the engine, running the electric fan, poor alternator
jrichker said:Under no circumstances connect the two 10 gauge black/white wires to the 3G alternator. If the fuse blows in the 4 gauge wire, the two 10 gauge wires will be overloaded to the point of catching fire and burning up the wiring harness.
mike0227 said:Figure this:
Ignition system & computer = 12 amps
Fuel pump = 12 amps
Exterior lights = 15 amps
Fan (heater or A/C) = 15 amps (can run between 5-25 amps depending on setting)
Radio & instruments = 10 amps
Wipers = 10 amps
That's grand total of 74 amps from a 65 amp alternator. Talk about overdrawn at the bank!
ok figure this you stock mustang alt is at 65 amps but.......... ALL alternators are rated at 85% max output for reliability resons! 65\85%=76.470588 amps! And if all your stuff is pulling that many amps you have a problem! A cpu pulls maby 2-5 amps MAX! your spark systems dosent need amps due to the laws of electromotive force and step up voltage transformers! bigger alts are a waste of money if you dont have a "big" bumpen system your car will do just fine with a elect fan it will pull about 15 amps!
Note fuses are there to protect wiring not the componits!
Oh yea ASE master Certificate # lu0mp6x04mcgro
And FAA Airframe and powerplant #2799069
Oh and faa pilot single and multiengine aircraft#2799069
If you measure the resistance of a typical ignition coil, you will probably get .4-1.0 ohms. Using .5 ohm as an example (I=E/R), thats 24 amps of current. The inductive reactance ( Xl=2pi times fL) of the circuit causes coil's resistance to increase to about 1 ohm, reducing the current to about 12 amps, but not down to a low figure like 2-3 amps at low speeds.mike0227 said:"your spark systems dosent need amps due to the laws of electromotive force and step up voltage transformers!"
I realize that you have far more knowledge and experience than most other people who post here, but I've read 5 or so magazine articles about doing the 3g upgrade, and they all say to make sure to reconnect those wires, supposedly because there are circuits which depend on power from those wires, which apparently aren't satisfied by the 4 gauge wire you run. I'd like to see a full wiring diagram to prove that wrong once and for all, because I personally would like to know which way is correct.
