Good question. I see everyone saying use a fuse/circuit breaker but they rarely mention a specific size to use.
How about the 3.8L Taurus fans, what size is reccomended with those?
Is a circuit breaker any faster or more consistent to react than a fuse? How do you reset the small 12V circuit breakers, by removing current to it (by turning the ignition or fan switch off)?
I'm installing my Taurus fan with a soft-start controller that doesn't require a relay but I'm still a little confused what kind of circuit protection to use. I don't believe the instructions specify what amp rating is needed. I believe the controller is rated for 30-35 amps, so I figured I'd go with a 30 amp fuse (or circuit breaker)? Any comments?
