electric fan installation (info inside)
Hi all.
This is just a FYI for my electric fan installation. I thought it might help others...
93GT, stock radiator
INstalled a FLexalite #210, 2 X 12 inch fan + controller
Brothers Performance warehouse web site says "direct fit 79-93". Not eactly true.
Dislikes:
1. Fan is 2 inches longer than fin area on stock radiators. Fixed by removing petcock and pluging drain. (now drain by removing lower radiator hose).
2. Capilary tube design for thermostat is much too delicate a design (copper tube). Could be easily broken or kinked. Mounting method inside upper inlet is just aking for a leak.
3. Thermostat option did not work on my unit. It did not control the turn-on time at all. Very dissapointed in this design. Ditched supplied t-stat and substituted with an industrial temperature switch used for process monitoring (from my work).
4. Temp adjustment knob is too short. My fingers can't even get ahold of the potientometer. Put a freekin knob on it! Requires a tool to adjust. Should be "tool-less".
5. Crimps supplied are exposed, non contact insulated spade females. These should always be insulated spade females. This will prevent you from blowing a fuse (or melting the battery wire) if a wire accidenatlly pops-off or during troubleshooting (like when trying to figure out why the hell the t-stat doesn't work!). I immediately threw the supplied crimps out and substituted high quality fully insulated crimps.
6. 2 of the 4 wire bundles supplied were not identified with temperature rating info (fine print found on the insulation jacket of the wire). I threw all supplied wire out and used 105 Celsius gas/oil resistant wire. I did not trust the wire supplied as it looked like it was vinyl or butyl or low temperature PVC insulation.
7. Fuse holder supplied is 30 amp mini spade auto fuse. Why use a "non-standard" auto fuse. Threw this out and replaced with a standard fuse holder. This keeps my fuse inventory down.
1. quiet operation.
2. Cooled just slightly better in stationery operation. Blows like crazy!
3. Low current draw. 20 amps.
4. Very slim unit (less than 3 inches). Opens up the front area nicely!
5. Easy radiator attachment. Was nervous about running ties though the radiator....but it seems to work.
Custom mounted overflow bottle by making a bracket. Same location, just needed a bracket. details...details...details
Overall, it is a nice unit and works as expected for its purpose. However, I was VERY dissapointed with the accessories kit and the controller. A simple afternoon installation turned into 1 1/2 days because I had to buy and substitute the wiring / accesories and the temperature t-stat.
Just wanted to post my experience.
I bet that wouldn't cool my 351W in the Summer down her in New Orleans. I tried a Black Magic...crap.
Flex fan - CRAP
Had to use a Lincoln Mark VIII, with a Griffin 31X19 alum rad, water wetter and pure water. Any antifreeze and the car runs warmer. I currently keep temps of 190-220. Before I could peg the temp gauge idling!
210 felx a lite
thanks for the info i'm in the process of installing one right now. the parts kit sucks and the thermostat is kinda cheap! the fan itself looks good except like you said it hangs over the tanks on the radiator. i made my own brackets so the fan is not going anywhere! i just hope i don't have any problems with the t stat controller. i believe it's the only electric fan the will fit with a 3 core radiator and a 8 groove blower belt. if anyone has any questions i'd be happy to answer them. thanks jason 89 gt :D
210 flex a lite
quick question the instructions say to wrap the radiator hose inlet where the t stat sensor goes with vinyl tape. then install the gasket and hose with clamp. what the heck is vinyl tape?????????? thanks jason 89gt
210 fan
thanks for the info. i got everything hooked up except for the one positive wire. anybody know what a good ignition hot wire that would be good to tap into under the hood? i could hook it up to the battery but i want the fan to shut off when the key is off. thanks jason 89 gt
210 flex a lite
no actually it is the turn on lead for the temp sensing probe in the upper hose. it is not powering the fan it only feeds low amp power to the temp sensor. the main positive lead comes straight from the battery. i kinda want to wire it in the engine compartment because i have enough going through the firewall grommet. thanks jason 89 gt
210 fan
i've got a problem with my 210 flex a lite fan. in your post you said it was a quiet operating fan. my fan vibrates the whole car have you ran into any problems with vibrations? thanks jason 89 gt
Idwitheld-1` said:
Hi all.
Dislikes:
1. quiet operation.
electric fan
kinda sorta maybe the fan is okay but having problems with alternator (i think) the car is fine when first started but when everything get to operating temp and the fans kick on i'm getting a major vibration like the alternator i having to overwork. this only happens when everything is warmed up. i can turn the fan on when the car is cold first started and no vibrations UNTIL the car warms up!!!!!!!!!!!!! I've tried 2 alternators same with both. any ideas?????????????????????? :bang:
I have the 210 dual flex fan in my cAr. I paid $225 for it. I installed the fan in about two hours. No leaks, no vibrations, complete kit with an adjustable t-stat. So far so good. No complaints.
