electric fan question
jmd2914
937
Napa, California
alright im about to do my alt and electric fan upgrade here in a week or two and i have some quesitons, ( did search). im planning on going with a 2g 140 amp alt and the proform fan kit. do i need to buy a 180 or 160 deg thermostat along with the fan and alt? and what kind of gains can i expect after doing this swap? i know its not much im just wondering
Use the stock thermostat if it is working good now. Using a 160 degree unit increases gas consumption and doesn't do anything for performance.
I recommend that you do with a DCControl fan controller. See www.dccontrol.com It will allow you to taylor the fan on/off points to your preference. It costs a little more than a relay and thermo switch, but is well worth it. The kit has a fan controller that only uses enough electrical power to keep the water temps in the range you select. This is assuming that you have a properly functioning cooling system to begin with.
The quality of support, if needed, has been excellent here on Stangnet. Baskin (DCControl tech guy) is right on top with the answers when you post a DCControl question.
As to power gains, see
http://www.dccontrol.com/techwrk.htm[/url] for more information. There is definitely some HP to be gained in a properly designed & installed electric fan setup.
Nice info from JR. :nice:
It is worth mentioning - I think that "2G" part was a typo. But if you had your stocker somehow rewound for that amperage,, you would have amperage-handling issues. The stock wiring and connector cant handle that much juice, plain and simple.
I think it was a typo so the lug on the back of the 3G will allow you to connect your new power cable with no issues.
Good luck.
alright, so let me see if the thermostat was explained to me right, pretty much if i got a lower deg one the cooling system would start opperating at a lower temp, which would keep the engine cooler? or am i wrong. but i dont really need to do this cuz it doesnt help me performance at all?
In an adequate cooling system, the car will not get much hotter than the rating of the stat (this does not consider stats themselves being inaccurate. A balanced stat remedies that situation anyhow).
WHen people have inadequate cooling systems, they try to prolong the inevitable (running too hot) by running a 160* t-stat. This does allow coolant to start flowing sooner, but it just gives someone a few more minutes before the inadequate system is running behind again.
Does the alt have a power cable lug?
Good luck.
Yea as said above be really careful with the wiring of the alt, it needs to be upgraded. As for the fan I think you will be pleasantly suprised. My fan clutch was really sticky was one all the time, warm or cold. The car now idles better, you can actually hear the exhaust, and made a seat of the pants difference. Sadly it went from on decent traction to just over the edge, but cant say I can complain. :D
With my electric fans and aluminum radiator, my car runs @ 120*F when cruising highway speeds. And will bump up to 180*F when riding it hard around town. On a very hot day, it's up closer to 200*F around the town and 150*F on the highway.
jmd2914 said:
im gonna ask kind of a dumb question here, how would i know if the alt has a power cable lug? ive never really done much with one before
You said you have a 140 amp 2G alternator. I just was curious if that was a typo or not. I cant think of a feasible way to make a 2G wiring connection to handle that much current. That was why I was asking in my first post and later.
The stock alternator does not have a lug on the back where the power cable attaches. 3G's do.
Good luck.
jmd2914 said:
oh, yeah it was a typo, i have my stock alt right now im probably going to get a 3g when i do my fan. does a 3g bolt right up?
Not quite...
Here's websites with pictures of the 3G installation...
See http://www.geocities.com/smithmonte/Auto/3G_130A_Alternator_Upgrade.htm - all the tech data you could ever want to know
OR
http://www.mustangcentral.net/tech/alternator.html - excellent pictures of installation
Use these sites for information on the right way to do the wiring. Some people will tell you that you can skip the wiring upgrade, but it will catch up with you sooner or later. A fire in the wiring harness is ugly and expensive.
Under no circumstances connect the two 10 gauge black/white wires to the 3G alternator. If the fuse blows in the 4 gauge wire, the two 10 gauge wires will be overloaded to the point of catching fire and burning up the wiring harness.
The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects.
Electric fan = 3G alternator if you want long life & reliability from your car.
The electric fan saves some HP. The stock fan's parasitic drag runs from 7-12 HP depending on who you talk to. The electric fan uses about 1/2 HP of power from the electrical system.
Figure this:
Ignition system & computer = 12 amps
Fuel pump = 12 amps
Exterior lights = 15 amps
Fan (heater or A/C) = 15 amps (can run between 5-25 amps depending on setting)
Radio & instruments = 10 amps
Wipers = 10 amps
That's grand total of 74 amps from a 65 amp alternator. Talk about overdrawn at the bank!
See WWW.partsexpress.com for the fuse & fuse holder.
Fuse @ $3.90 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=071-952
Fuseholder @ $5.80 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=263-630
4 gauge black wire @ $1.25 a foot (use string to lay out routing & determine length) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-196
4 gauge red wire @ $1.25 a foot (use string to lay out routing & determine length) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-194
4 gauge ring crimp terminals (package of 5) $3.25. http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=095-584
i know i need to do the wiring upgrade to 4 gauge ( thanks for the sites those are gonna help when i do it) but does the 3g bolt into place just like the stock one? and all the stuff you listed to buy on partsexpress.com, would a local parts store i.e. kragen or autozone carry all that stuff?
Check out Mr. Smith's write up and MC's write up that JR posted links to above. They outline the the procedure. I think JR also has a self-authored post where he outlines how he did his (it was a very nice concise synopsis IMHO).
I used all the parts that JR linked to, from PE. Also grab some heat shrink if you dont have around your shop that is that large (I didnt at the time). If you make your own ground cable as well, you need two packages of eyelets.
You could cobble the stuff together locally, but I bet you would be money ahead to pay shipping and get it from PE.
Good luck.
I recently bought the 3g upgrade to 140amp from PA performance, I had a upcoming race and did not want to fool around with locating this and that parts. Kinda expensive, but worth it IMO. I have a ProForm fan. It is the biggest POS I have ever wasted my money on. I would have been better off to send you the $$ and save myself the hassle. It never turns on before 200deg and doesn't move air for shi%. I went with a better clutch and lighter mech fan and I am happy.
Also with the ALT I bought the power wire from them, and upgraded the other wires as suggested in previous posts. I run Nitrous, and I really try to limit the possibility of any arcing under the hood.
Fire Baaaad!
