Michael Yount
Mustang Master
87ttop - how did it cool down to 145 with a 180 t'stat? If it really did, then your t'stat isn't working like it should.
ok, im needin some more info cuz im dumb. are ya familiar with the weep hole that Michael was talkin about? if not, look underneath the pump. you will see a small hole (manufactured into the pump). when the seal inside goes south, water will leak out of the hole. it normally leaves a telltale stain down the pump body. then it will drain down whereever gravity takes it.1991vert said:back to my water pump dilema. it only leaks when the car is on and the belt is turning so i dont think it's the seal. when the car is off it stops dripping so it must be cracked or something?? then again coolant expands so i dunno. it wouldnt be because i put too much coolant in, right? correct me if im wrong but it would just go into the overflow tank...
87 T-Top, i agree with ya totally - we all appreciate Michael's knowledge with cooling systems, amongst all the other areas.87TTopGT said:I don't know, I was measuring temperature of the water at the fill hole and inside "V" portions of cooling fins- don't know much about thermostats, how quickly do they open and close? Or is mine faulty?![]()
P.S.-Appreciate all the fan info you post, helped me out a lot!![]()
Michael Yount said:Hissin/87tt - that explains it. The t'stat does open/close relatively slowly over a range of 3-5F degrees. But if working properly, it will keep the coolant at the open/close temp -- if measured right at the t'stat location. That's always at the outlet of the engine -- which will be the hottest location. If you measure elsewhere, it will be cooler - which is what occurred. When you said it cooled to 145F I thought you meant on your car's temp gauge (which also measures near the t'stat housing - the hottest part). I measured the 180 t'stat in my car - it began opening at 182F and was fully open by 185F. So they're all a little different.
1991vert said:well i just got a new FMS 3core Aluminum radiator and it runs at 180'ish, but it climbs slightly when sitting for a while (stock fan clutch). i have a 130amp alternator with underdrive pulleys, so im all set up for an electric.
thank you very much for the insight, Guru.Michael Yount said:I believe closed loop operation relative to coolant temps is a bit of a myth. The issue is simply whether or not the O2 sensors are warm enough to start generating voltages for use by the ecu. The ceramic material in the sensor must be at least 570F before it starts working correctly. Consequently, it can take as long as 90-120 seconds for an unheated O2 sensor to get warm enough to start working properly. In most 88-93 eec systems, the O2 sensors are heated to get them operating more quickly. A heated sensor may be hot enough in 10-15 seconds to generate voltage and allow closed loop operation. So, a minute or two at the longest, a few seconds at the shortest and you're in closed loop. All this according to Probst book on the Ford ECU. Verified on my car which had no problem achieving closed loop (19 mpg city/26 mpg hwy) with a 170F t'stat - even in our occasional 5F-10F cold mornings in Jan/Feb.
miamifiveoh said:Minor quibble: The FMS aluminum radiator (M-8500-C) is a 2 row/core radiator. It is very wide because the cores are 1" wide, but it is not a 3 core.
gotta love false advertisement i guess. gonna pick up the stock pump tomorrow for a whopping $30 w/ discount included. it's funny, little things like this annoy me, but doing a big job like a tranny swap is actually fun to me
