no prob Derek. another thing that i do like to do (and you do too probably) is put a small fuse (1 amp if i can find one, otherwise a 3 amp) on the 12 volt+ and light feed from the fusebox (and for lighting, fuse 13 or the dimmer or whatever your chosen source is). that way, should a problem arise in your wiring, it should not take out the dimmer fuse and your stock gauges' lighting. im sure you wiring is great - but i like to do things that way myself. also, should one of the other circuits [that you tapped power from] get a short, the little fuse would hopefully blow and be more gentle on thegauges and their wiring (rather than waiting for a bigger stock fuse to blow). just something i do.
enjoy the new gauges - one of the most satisfying things to do, IMHO. take care Derek.
