  • SN95 V6 Mustang Tech
Electrical Help!!!
  • Thread starter Thread starter kidd649
  • Start date Start date Jun 28, 2011
K
kidd649
FLorida Keys
Jun 28, 2011
  • Jun 28, 2011
I went to the store to grab some donuts...(go figure!), as I was walking back to my 2004 V6 mustang, the remote control would not work...thinking it was just the battery in the remote, I opened the door the old fashion way with the key. When inside, I heard a bell chime that was going off constantly and the interior overhead light was on, but I could not control either. I decided to get home and check it out there, as I left the parking lot, I noticed that, nothing electrical worked...the wipers, brake light, nothing, but the car was running fine.
I got home took the fuse panel cover off ...pushed it back on and the lights and blinker were working again, however, the interior light and the chime were still active...is there a reset procedure I need to know about ?... I am sure it is a fuse or electrical problem, and I will work on it after my donuts...of course... Has anyone run into this problem and can help...this will save me from pulling out what little hair I have left!
quique
37
Houston TX
Jun 28, 2011
  • Jun 28, 2011
There is another fuse box inside the car just under the steering colum kind of hidden. Give that one a check see if any more fuses went out. When one fuse goes out most likely another followes with it.
K
kidd649
FLorida Keys
Jun 29, 2011
  • Jun 29, 2011
Thanks, I checked the one under the steering wheel and they all appear good. I did not check the one under the hood, however, I used a code reader and no code was detected. I checked the electrical about 2 hours later after disconnecting the battery and it seems to be fine now with no chime or interior light going off. Someone suggested a possible ground being wet....Have you heard of that and is it possible?
quique
37
Houston TX
Jun 29, 2011
  • Jun 29, 2011
Last time i had something electrical happen to me, i checked both fuse boxes and replaced fuses that were out. Unhooked the battery for about 45 min to let the computer reset. Everything started to work fine after that and have had no problem since then. I havent heard of any grounding being wet. Thats a new one for me with the electrical grounding being wet. I havent heard of that one but hey that might be it.
Let me know what you find out.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 4, 2011
  • Jul 4, 2011
Sure sounds like a weak battery or loose dirty battery cables to me. Start there.
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
L
Electrical issue
  • Landonf00
  • Aug 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 10, 2025
Landonf00
L
