Electrical Issue?
HISSIN50
33
129
fist thought is that when you start it, it is at fast idle.
once warm and at hot idle, and with your U/D pulleys, the alt is not spinning enough.
just my thoughts. good luck.
ratrapp
510
buena vista,va
that's actually normal.my car does the same thing even with the 3ga conversion(highly recommend even on a stock stang).the reason it charges more when you first start it is because the battery needs a charge.after it runs a while the battery is charged and the alt. doesn't have to work as hard.remember an alt. is kind of like an ignition coil.it'll only produce the needed voltage when it needs it or it would be constantly running at full capacity and it's life would be short.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,513
2,854
234
Dublin GA
The middle mark on the stock voltmeter is supposed to be 14 volts. The next full mark below is 13 volts, and the next full mark above is 15 volts.
The voltage regulator will drop the voltage slightly as the alternator & battery warm up. This is to keep from overcharging the battery & causing it boil off the water/electrolyte.
