I pulled a stupid move about a year ago when i tried to convert over to electical fans instead of pulley driven ones. about halfway through the install I realized I hadn't figured out a way to activate the fans. Most modern cars have a temp sensor. Anyways, I was looking through a wiring schematic and found the coolant temperature sensor. I figured I could just ground the fans off of that and boom it'll work when it needs too. I learned a thing or two about sensors and the sensitive electronics in a car that day. As soon as I ground it the fans spun for about .3 of a second and then i heard faint snap and the fans quit working. I then pulled out the fans and tried to start the car. Just turned over and over. After banging my head against the wall for a while I just gave up and would start the next day being as it was late. Next day it miraculously started up and seemed to be running fine. So I just set up a toggle switch directly to the battery. After the install I drove it around, everything seemed fine so I went to fill it up. After I was done pumping the gas I went to start it up and (this is where it gets hard to explain) it turned over a little and then I let off because after the first turn or two it usually fires up and it just died. I went to turn in on again and it just turned over and over like when I first thought I killed it. It woudln't start again for about 45 minutes. I got home and decided to hold in the ignition and it'll kinda die and then it'll fire right up but with a nasty high idle.
I followed the wiring schematic and that wire i tapped into basically goes straight to the computer. My guess is I either fried my sensor or I fried part of the computer. The temp gauge worked for a while but now it is dead as well.
Just curious if anyone has any ideas. I'm sure it isn't a duplicate situation because I'm sure nobody was as ignorant as I was when I did it. The sensor is like 15 bucks and the computer is a hundred bucks + core.
BTW it's a 1990 5.0
Any help would be greatly appreciated.
BTW it's a 1990 5.0
