OK, let me start by saying electrical is NOT MY THING....AT ALL. Anyway, The airbag module (blue one under the stereo in my 94 cobra) fried. It smells burnt. I took it out, and pulled the top blue plastic off and I can see the one of the parts is burnt. Through research I see that it is Metal Oxide Varistor MOV40? Whatever that is...So, here is my questions. I was blowing fuse #4 (airbag module fuse 10 amp) every time I would put one in. It seems that this module was the culprit, but to verify if I put a fuse in the #4 slot without the module being plugged in, if there was a wiring problem prior to where it plugs into the module would the fuse blow? And if it doesn't blow can I safely figure that the module itself is what was causing the fuse to blow?
