electronics guys- come in, delay question for E-fan...
To start with, I know about the DC controller...
Alright, I am going to be setting up my own budget E-fan controller using 3 relays in series, 2 temp probes and a 2spd fan. The first relay will be closed normally but switched open by ignition, the 2nd will be closed normally but switched on by a/c being on or by temperature setting of first temp probe. This will turn low power on E-fan of 3rd relay prong 87a, when temp of 2nd temp probe ( a higher temp than first probe) is met, 3rd relay will switch to prong 87 for high speed fan function. <-- third relay is 5 prong or SPDT.
I know about using diodes on a/c, so that temp probe 1 will not turn a/c on
and using diodes across the coil of each relay and between the + and - of the fan so that the stored energy can bleed back to ground and not damage relays.
Alright that is the plan, my question is- Is there any type of electrical delays I could use, so that when the car is being started, the fans will not turn on, preventing power theft from my starter. ( Power delayed for 5-10 seconds before going to first relay)
I noticed some sort of delay thingy's at a local electronic supply place but was unsure of their function. Keep in mind proper amp rating for my fans.
Sorry for the length and thanks for your help.
