Emgine building help
  • Thread starter Thread starter 1990blackgt
  • Start date Start date Jan 16, 2007
1990blackgt
10
  • Jan 16, 2007
I just got my stock, tired old 302 disassembled and ready to go to the machine shop. So far it'd getting bored .30 over, new cam bearings, and freeze plugs installed. My questions are... Do I need to get anything done to the crank, or if i get a new crank... the main caps??? The shop is pressuring me to buy the pistons and whatever else so they can install it... but I wanted to do that myself. Also I wanted to save the money. What do I need to know to assemble the engine correctly after the machine work is done? The combo i have for it so far is GT40P heads with beefier valve springs, will probably get them ported and polished before install... Cobra upper & lower intake, and B303 cam... help/opinions are appreciated THX
1Bad88notch
62
Leesburg,FL
Jan 16, 2007
  • Jan 16, 2007
I would go ahead and let the machine shop put it together for you. Im in the same situation as you, but im getting a 331 stroker kit comes with everthing you need.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jan 16, 2007
  • Jan 16, 2007
i'd rather put my own engine together myself. you learn more, get more expierence with your car, and nothing beats the feeling of when u first start the engine, and hear it roar knowing that YOU did that.
let the shop clean and bore the block etc.. if u want to assemble yourself. DO IT, i did and it was a blast.
all the work i had my machinist do was, clean and hone block, cam bearings, plugs. and he freshened up a set of thumpers i bought. i did the rest myself.
if your crank is in good shape no wear. reuse it! no need to get it turned, for just a street application it will be fine. i just cleaned my crank up with emery cloth.
what year car is the engine from, if its 87-92 they have forged slugs, if its 93 they are cast hypereutectics. if you have a forged set and in good shape! REUSE THEM! like before, for a street application it will be fine. i got a set of good stock forged pistons for my build and they work great!
ozanracing
172
  • Jan 16, 2007
Get your crank turned 10/10. Means .010" smaller journals on the mains and rods.
If they look fine (doubt it) just polish them with emry paper and a string.
1990blackgt
10
  • Jan 16, 2007
what type of power do you think this combo will make?
ozanracing
172
  • Jan 16, 2007
260-270 To the wheels.
1990blackgt
10
  • Jan 16, 2007
is this combo sprayable? maybe a 100 shot?
ozanracing
172
  • Jan 16, 2007
For sure! Just make sure you have the nessecery supporting mods for nitrous. IE: bigger injectors if it's a dry shot, high volume fuel pump, back off the timing, colder plugs etc.. A window switch is also nice...
I have this one, it's excellent:
http://store.summitracing.com/partd...1&part=MSD-8969&N=700+400122+115&autoview=sku
1990blackgt
10
  • Jan 16, 2007
I wonder if boring .30 over is really necessary... i could get off cheap by getting the block cleaned and re-ringing the factorey forged slugs...
ozanracing
172
#10
  • Jan 16, 2007
  • #10
I wouldn't....
1990blackgt
10
#11
  • Feb 16, 2007
  • #11
I got my tax return today, and want to get my motor done with it. It's 2,000.00. What can I get with 2k, and a used block?
vristang
4,933
101
124
Seattle
Feb 16, 2007
#12
  • Feb 16, 2007
  • #12
The machine shop will need to have the pistons in hand when they bore/hone the bores.
This way they can hit the clearance exactly where you want it...
jason
mustanggt5pt0
34
Cedar Falls, Iowa
Feb 16, 2007
#13
  • Feb 16, 2007
  • #13
Do NOT just hone the walls and put over-sized rings on. I did that and guess what? Burns a quart of oil every 300 miles. The ring gaps were within spec too. Seriously don't do it, it was a real bummer knowing all the work I did was pointless. But hey I guess it is giving me the chance to start over and rebuild again in a few weeks!
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Feb 16, 2007
#14
  • Feb 16, 2007
  • #14
If your going to do it, do it right, that is all I have to say.
1990blackgt
10
#15
  • Feb 16, 2007
  • #15
Anybody got an idea what i can do for $2000.00
vristang
4,933
101
124
Seattle
Feb 16, 2007
#16
  • Feb 16, 2007
  • #16
In reality there are far too many possibilities with $2,000.
What do YOU want to do?
a simple rebuild could do quite well. If you want to get more involved there are stroker kits, then 351w swaps.
It depends on what YOU want.
jason
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
5K
Classic Mustang Specific Tech Thursday at 6:45 AM
DadLife0724
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
