88GTStreetRod said:
What emission friendly mods can I do to a stock motor? I need ideas on cams and heads. I have a budget of about $4000
Is the $4000 engine only? If so I run 306, ARP rod main and head bolts, Forged flat tops, balanced, aluminium edelbrock 2.02 heads, rpm intake, e303 cam, cobra rockers, 76mm MAF, 75mm TB and EGR, I'm still using stock injectors. You should be able to get into somthing like this for around $4000.
This setup flew through emmissions (in Ontario Canada), in fact it beat my girlfrieds saturn in everything but hydro carbons.
It also runs 13.1 @ 107.1 mph on street tires and 12.8 @ 105.5mph on stickies, this is with all emmisions contol but cats.
If you can substitute AFR 185 Emmission legal heads, RPM II intake, 24lbs injectors, and Bassani cats this would make a pertty hot street pounder and keep it legal.
