Emissions test=Failed!! HELP!
  • Thread starter Thread starter MahFiVeOh
  • Start date Start date Jun 30, 2006
MahFiVeOh
531
9
49
Ontario, Canada
Jun 30, 2006
  • Jun 30, 2006
I just had an emissions test done today and my car failed!! The readings were ....
HC ppm Limit=66 My reading=58 PASS
CO% Limit=0.37 My reading=0.01 PASS
NO ppm Limit=0757 My reading=1834 FAILED!!!
Idle readings all passed.
Now i need some help as to where to start looking for my problem.I had new headers and H pipe installed before winter so i doubt it is an exhaust leak.My car has 165xxx kms on it and i change my oil every 3-4000 kms so the motor is still running ok in my opinion.Just curious where should my timing be set at for a basically stock 5.0L?? From what i saw it looks like it is at 12*( is each line on the balancer 1 or 2 *?? )I run 87 octane gas 99.9% of the time.I'm on a tight budget at the moment so i need to get this fixed asap without spending tons of $$ PLease help
Oh did i mention emissions testing sux!!
Thanks
mustanghunter50
123
easton pa
Jun 30, 2006
  • Jun 30, 2006
find someone who will just give you the stickers without the test
MahFiVeOh
531
9
49
Ontario, Canada
Jun 30, 2006
  • Jun 30, 2006
Thats pretty hard to do around here in Ontario.I have to bring the sheet with the data to the Ministry of Transportation in order to get my plate sticker.
89SaleenGT
32
  • Jun 30, 2006
NOx is way up. timing for a stocker should be set about 8-10°BTDC with spout removed.
Car sitting at idle passes.
OK,
Set the timing then check the EGR if it is working.
If the car was on a rollers a cause of excessive NOx is a non-functioning EGR.
vristang
4,933
101
124
Seattle
Jun 30, 2006
  • Jun 30, 2006
First thing to do is pull the codes from the computer.
I would suspect that your egr system comes up.
jason
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jun 30, 2006
  • Jun 30, 2006
Yeah, tell me about it. That's why I got the the '68(pre-'75 is exempt here). Too bad I have to get the SVO checked; they're usually hard to get to pass.
Since NOx is the only thing that went too high, I also suspect an EGR problem.
Sometimes a rich condition will make the cats burn too hot and raise the NOx, but it also elevates HC and CO. Both of those were low for you, leaving pretty much the EGR.
MahFiVeOh
531
9
49
Ontario, Canada
Jul 1, 2006
  • Jul 1, 2006
ej95cobra
82
Southeastern PA
Jul 1, 2006
  • Jul 1, 2006
With NOx high and everything else fine it means your cylinder temps are high. I had the same problem in PA.
HC limit 0275; test = 175 passed
CO limit 1.10, test - 0.05 = passed
NOx limit 3600; test = 4270 - Failed
Car may be running lean. You could plug the vaccuum to FPR, that will increase fuel; but may throw other measures off. Also as noted above, you could retard the timing. I went to 7 degrees timing and plugged the FPR vaccuum; measures were:
NOx = 1565 = passed
CO = 1.55 = failed
HC = 570 = failed
Try putting in a lower temp thermostat (160*) to get past emissions. That's what worked for me. I also put timing back to 10*. Here are the readings"
HC = 220
CO = 0.2
NOx = 2530
Good luck.
stangjunkie
381
  • Jul 1, 2006
retard the timming and try again still nothing then unplug an injector
vristang
4,933
101
124
Seattle
Jul 1, 2006
#10
  • Jul 1, 2006
  • #10
I am always amazed at the suggestions for passing emissions tests.
Do not un hook an injector.
Do not install a 160 stat. (unless your local weather dictates)
The majority of emissions failures also indicate that something is wrong with the motor.
Fix the problem!
Don't create new problems!
Pull the codes!
jason
65ShelbyClone
4,675
38
119
Jul 1, 2006
#11
  • Jul 1, 2006
  • #11
Definitely don't do that. It's possible the engine will not come out of warmup enrichment. I suppose that could cool down the combustion temps, but also at the expense of HC and CO emissions. I actually put a 195* in my '89 GT before getting it tested. It had a MAF, headers, and Flowmasters on a 180k engine and never went over half the limit for any emissions. I don't know if I still have the old smog sheets for it...
The only reason I didn't get caught on the shorty headers is because they were Flowtechs that turned rusty and looked stock.
ej95cobra
82
Southeastern PA
Jul 1, 2006
#12
  • Jul 1, 2006
  • #12
The issue is getting past emissions inspection. The 160* will help keep the chamber temps lower thereby reducing the NOx. It will not significantly affect HC or CO emmissions. You can put a 180* or 195* back after passing inspection and spend as much time as you want chasing other causes.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Jul 1, 2006
#13
  • Jul 1, 2006
  • #13
with cats on the car there is NO reason why you can't pass...pull the codes and set timing at 8deg, leave the spout out for the test.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
ECU help!
  • starkiller1134
  • Aug 16, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
Cali Members, Get in Here! - Smog issue with possible error on 2007 Shelby GT Emissions label failed due to EGR
  • saldua
  • Mar 30, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Apr 1, 2025
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
