Energy Suspension, NO INSTRUCTIONS! Help
URNEXT
112
Orlando Fl
Energy Suspension Polyurethane Master Kit for 93 did not come with directions. The front went in fine but the upper and lowers in the rear are making me scratch my head. The new ones have a ring that slide over the bushing. Where do they go? The stock bushings have a steel sleeve that the rubber sits in but the new does not have the steel sleeve. Do I just remove the rubber from the stock bushing and install the poly into the old sleeve or what? Please help all of the stores are closed today. Thank you for your help.
Thank you sir, I will burn them out.
Now where do those rings go? I still have them oriented the same way they were packaged. (Flat side towards the largest diameter of the bushing, champhered side to the small end of the bushing.)
