  • SN95 4.6L Mustang Tech
engaging clutch
  • Thread starter Thread starter evil281
  • Start date Start date Oct 16, 2008
evil281
276
Arizona
Oct 16, 2008
  • Oct 16, 2008
ok so my 99 gt t-45 clutch pedal has to be pushed way farther than my friends t-3650 pedal to engage the clutch, what could this be from? just because its a different trans? stretched clutch cable? his just seems like u barely have to push far and the clutch engages, mine has to be pushed a mile in before it works, makes its way easier to shift faster in his car
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Oct 16, 2008
  • Oct 16, 2008
I don't really like that mine engages so early. That means it'll engage fast but then i have like a mile before it FULLY engages(meaning hits the floor). Just get a quadrant/firewall adj./cable kit and you can adjust it to where you like it. Does yours halfway engage if you halfway push the pedal?
evil281
276
Arizona
Oct 16, 2008
  • Oct 16, 2008
ya it will engage about half way which i hate cause when ur shifting fast u still gotta push it down all the way as not to miss the gear cause u didnt engage it all the way
my friends on the other had engages like when its pushed all the way down and doesnt seem to come up as far as mine so its alot quicker and shorter
02nightmaregt
Jul 1, 2007
513
Southern Indiana
Oct 16, 2008
  • Oct 16, 2008
its most likely the difference in transmossion types. Just do the swap i mentioned and you'll be set. BTW the brakes look sweet
evil281
276
Arizona
Oct 16, 2008
  • Oct 16, 2008
thanks man! also ive heard its better to stick with the stock cables and things, have you done the swap? do u like it?
02nightmaregt
Jul 1, 2007
513
Southern Indiana
Oct 16, 2008
  • Oct 16, 2008
I havent but i'm really looking in to it. I would just rather have the pedal close to the floor and not have so much pedal movement to engage. I would like to not replace the cable, just the quadrant and adjuster. It'll make for quicker shifting and less leg movement
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
T
Mcleod Hydraulic Clutch
  • TheJay806
  • Apr 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2025
limp
Engine 88 5.0 clutch engagement seems wrong.
  • 1yesfan
  • Apr 13, 2025
Fox 5.0 Mustang Tech Apr 13, 2025
1yesfan
T
Hydraulic Clutch
  • TheJay806
  • Mar 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2025
nickyb
