Engine bay dimensions for suspension alignment
  • Thread starter Thread starter 94Blue302GT
  • Start date Start date Aug 26, 2008
94Blue302GT
704
Chicago
Aug 26, 2008
  • Aug 26, 2008
The car i purchased has had an accident on the driver's side front corner. The hood and fender's seem to line up fairly well, but I'd like to know if there are some dimensions you could all help me with.
I have a 66 with a 289 4barrel.
I'm looking mainly at the distance between shock towers, distance from front to back of engine bay, and also diagonals of the bay.
Please state how you're measuring, and include pictures if possible!
Thank you a ton guys.
Blu3
tx65coupe
Sep 9, 2008
  • Sep 9, 2008
I have a 65. I'll see if I can't get some of those measurements for you.
tx65coupe
Sep 10, 2008
  • Sep 10, 2008
I took some measurements from my 65 for you to compare to your 66. Please keep in mind that my car although it is in very nice driver condition, it is not perfect.
Between the shock towers at the inner edge of the shock mouning bracket i measured approximately 30 inches.
At the lower inside of the frame at the sway bar mounting location I got approximately 27 3/4 inches.
At the center of the upper firewall just below the lip on the cowel panel to the front edge of the radiator support I got just under 40 1/4 inches.
Along the top edge of the radiator support between the inner fenders I got just under 41 1/2 inches.
Each side from under the cowel lip at the top of the firewall to the front edge of the radiator support I got 40 inches.
Diagonal measurements from the upper firewall under the cowel lip I got 56 inches from the passenger side rear to the driver side front, and almost 57 from driver side rear to passenger side front.
I think the reason that the diagonal measurements differ slightly is that the passenger side inner fender by the battery is different than the driver side.
94Blue302GT
704
Chicago
Sep 23, 2008
  • Sep 23, 2008
Thanks a ton man!
Hopefully this information gets used by someone else as well around here. I know I'm not the only one that needs measurements to get things straightened out.
Hopefully I don't have too much work ahead of me here, i'll post an update when i get to work on it a bit this weekend.
T
Terry Byrd
  • Dec 31, 2012
I repaired my cowl vents and replaced a section of the firewall and now my driver side fender will not line up to the mounting holes along the engine bay. These are replacement NOS fenders and everything else lines up fine.
Can someone with a 66 give me the measurements from the inside of the fenders and also from the engine bay at the hood hinge to hod hinge?
This would be a huge help.
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
