Well now that i have my engine out im thinking about boring it. i found a whole rotating assembly kit for 1400 with pistons .20 over, What size would that bore it to?
also what kinda estimated power do you think my motor would put out? and estimated 1/4 mile times. if anyone has the close to the same setup
here is my set up
01 4.6 block bored .20 over
Ported/Polished heads
Comp 270 cams & springs
Bullit intake manifold
As far as bolt ons i have
Long tubes, Off Road X, Flowmaster Catback
Eletric Water Pump, Jlt Cold air 90mm Lightning MAf
Underdrive Pulleys and Ac Delete, sct tuner
Drive Train - T56 Transmission, Aluminum Drive Shaft and 4.10 Gears
here is my set up
