rbohm said:assuming the rebuilder didnt break the cam in, then you need 20 min for cam break in(run at 2000 rpm minimum and dont let the engine idle in that period). after the cam is broken in you can dyno the engine.
as the cam spins at a faster rpm the lifters rotate in the lifter bores, if it idles,they dont spin and get worn and get flat.Thats why lifter should ne numbered when removed and re used,they get a pattern to them.NasaGT said:Not to hijack, why does a cam have to be broken in >> 2000 rpm for 20 minutes? I have never heard of this before...
cobains_dad said:hey guys i just talked to the garage and he said just break the cam at 2000 rpm for 20 min or so that should do the cam and get on the hwy and
start off at 30 and hard to 50 or 60 or so and then back down to 30 he said do that 4 or 5 times and that should seat the rings
67coupe351w said:other says break the cam in and run the engine as hard as you can (WOT or dyno) within the first 3 hours or so of its life.
The theory behind running the engine hard is that under high load the rings seat into the walls better while the hone is still on them providing a better seal for the life of the engine. light load or no load simple wipes the hone off the wall.
"The most critical part of the rebuild process is starting the engine for the first time and this is where many well meaning mechanics go fatally wrong. You MUST NOT let a newly fitted cam run at idle speed for the first 20 minutes of operation. Always keep the rpms up at about 2000 during this period. At idle speed the loadings on the cam 'nose' (that's where the cam is at full lift) are at their highest and the new cam can suffer permanent damage if it is allowed to idle before it has bedded in and work hardened properly. Sitting on the driveway with your foot on the accelerator for 20 minutes can seem like an eternity. Also if the engine starts to overheat it may be necessary to switch off, let things cool down and split the process into several shorter intervals"
)Edbert said:I'd hold off on the dyno myself, not for a break in reason but because the engine will still be "tight" and will probably post lower numbers than it would with a thousand miles under it's belt.
Why would anyone be worried about 'numbers' during a run-in, I just want to make sure my engine's running right and not doing itself any damage.Agreed, that was my pointozstang65 said:Why would anyone be worried about 'numbers' during a run-in, I just want to make sure my engine's running right and not doing itself any damage.
I heard you NEVER use synthetic on break on, i used Castrol for break in because it was on sale and i changed the oil after the 20 minute break in, after 150 miles and after 500 miles.Its cheap enough and takes maybe 15 minutesCobain03 said:do you think i should use our farms oil then? is 15w40 synthitic and is good up to 12k miles or so.
