engine build recommendations
92notch6886
15
im lookin at doin a build in the near future, a 306 possibly a lil bigger with edelbrock performer rpm heads 2.02/1.60 with the edlebrock rpm 2 intake and a 70mm tb, im not sure what type came tho. i want a somewhat rougher idle. my goal is 400rwhp that is for the most part a daily driver. is this possible and what type of cam is best??? also anyhting else that may be needed.
thanx for the advice and comments in advance
if your plan on making 400rwhp n/a you better build something bigger then a lil 306ci unless u plan on running boost.. in which case thats no problem..
but 400rwhp n/a out of a 306ci.. alot of compression and a big cam.. and bigger heads then those edelbrocks..
