Engine Build-Up
NosMe200
Worcester, MA
I'm rebuilding my '84 5.0L 306 engine in a few months, hoping to make some decent numbers out of it for a street car. It's being put into an '86 gt rolling chassis I recently purchased. I'm trying to figure out what to go with as for a carb, intake, heads, and cam...Looking for any suggestions/recomendations you guys have. I'm leaning towards an Edelbrock Thunder Series AVS Carb along with the Performer RPM Intake, but I have no idea what I want for heads and a cam yet. I'm hoping to get a nice sounding idle that's not too rough. I'm on somewhat of a budget but I would gladly scrape up a couple hundred bucks more if the performance is in it.
i dont like edlebrock carbs when it comes to performance, cruisers and dd's they are fine, just havent had luck with them on a performance motor
a good cheap budget head is the 97 and up explorer heads the gt40p head, they can be had for 300 a pair and flow better than stock, but not as good as aftermarket castings.
another decent option is a company called rhs they sell cast iron and aluminum heads at decent prices, you can get a set of bare cast iron heads for 400 bucks, that flow 200 cfm on the intake 68 on the exhaust use 2.02 intake and 1.60 exhaust valves and its on a 58 or 64 cc combustion chamber
the aluminum version of those are only about 150 dollars more
as for a cam shaft, stay away from the letter cams, they were good, but cam technology has come such a long way in cams, i suggest calling cammotion.com for a custom cam, only costs about 130 for a custom ground cam, exactly speced for what ever you want.
Ported E7s or GT40's from explore.. Intake a Weiand Stealth.. carb Street 600 vac sec/ street strip 750 vac sec Holley.. cam?? Nice rolling performance idle and still sweet street manners.. E303 or B303... dual pattern the TFS1 oe TFS2 camshasft.
Custom grindes are 350-375.00 for rollers... cool??
The above works great for a solid fun hard ride!!
Just me............................................
Thumper
The letter cams aren't that bad...and they're still fairly cheap...the only roller cams I can think of that rival their cost is the TFS stage 1 and 2 cams. Only thing is, unless your running a roller block (My '84 had a non-roller block), you'll have to spend close to $300 or more if you want to run a roller cam in a non-roller block.
If you don't mind a flat tappet cam, there are about a billion different grinds from which to choose, and they're not expensive at all. Most cam and lifter kits don't exceed $200, some of them (Crane energizer) are only about $130. Just take careful consideration into what all you want, what you can get, and what you expect.
If you were to build a zero decked flattop engine with GT40P's, you can expect about 9.5:1 compression with good quench (right at 0.040" with most head gaskets). With that, you could put about a 280-285* cam with about 225-230* @ 0.050" about 0.510" lift with that dual plane, a 600-650cfm carb, and have quite the fun little cruiser.
I'm kinda biased, but a Comp 270H Magnum, or a Crane 282 Energizer would run pretty damn well when properly complimented with a good drivetrain and suspension.
