- May 10, 2007
- 7
- 1
- 0
I'm in the process of building a 347 stroker, and I would like some thoughts/opinions on my parts selection, so be kind:
stock roller block-balanced,blueprinted and bored .030
forged rotating assembly with Probe SRS 12352-030 pistons
edelbrock performer rpm 2 intake
75mm throttle body/80mm maf cal. to 30# injectors
comp cams xe282 cam with 1.7 rr
afr 185 heads with spring upgrade
performance automatic AOD with 2600 stall
3.55 gears with posi
30# injectors and a 255lph pump
compression ratio with 58cc heads= 9.3-1
stock suspension, subframe connectors and 235/45/17 tire
JBA mid length headers and 2.5 inch flowmaster exhaust
so, how does this setup sound? Any thoughts/suggestions?Thanks again.
