  • 1994 - 1995 Specific Tech
Engine Chirp
  • Thread starter Thread starter stang3O2
  • Start date Start date May 20, 2004
stang3O2
200
Indiana
May 20, 2004
  • May 20, 2004
My car just started making a chirping noise and it is coming from the motor. The noise is faster with more RPMs U=I can't tell exactly where in the motor it is coming from. What are the possibilities? It has 157000 miles on it
Thanks
go-stang5.0
2,244
Glenview,Il
May 21, 2004
  • May 21, 2004
I would check to see if your belt is old or loose. Also, check to see if anything is rubbing against a moving part while the car is on. Also, check the bolts on all your pulleys, they could be loose. Finally if you have a stick it could be your throw out bearing, even thought that sound would come from further back.
JJ95GTID
1,141
Phoenix, AZ
May 21, 2004
  • May 21, 2004
Another possibility are the bearings on the idler pulley and the belt tensioner pulley.
DougNuts
2,596
Georgetown Ky
May 21, 2004
  • May 21, 2004
I agree with the other 2 guys, and also maybe your balancer is bad and rubbing on the motor?
go.rei GT
267
Az
May 21, 2004
  • May 21, 2004
My guess is this or the TO bearing.
I was surprised how quiet it was under the hood after I changed my idler and tensioner pulleys. I didin't think they were making much noise, but with the new ones on there is a night and day difference (mine weren't "chirping" though).
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Electrical MSD Blaster TFI Coil 8227 loud Chirping Noise.
  • PonyGTrider
  • May 25, 2025
Fox 5.0 Mustang Tech May 31, 2025
PonyGTrider
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
