Engine Chirp
stang3O2
200
Indiana
My car just started making a chirping noise and it is coming from the motor. The noise is faster with more RPMs U=I can't tell exactly where in the motor it is coming from. What are the possibilities? It has 157000 miles on it
Thanks
I would check to see if your belt is old or loose. Also, check to see if anything is rubbing against a moving part while the car is on. Also, check the bolts on all your pulleys, they could be loose. Finally if you have a stick it could be your throw out bearing, even thought that sound would come from further back.
JJ95GTID said:
Another possibility are the bearings on the idler pulley and the belt tensioner pulley.
My guess is this or the TO bearing.
I was surprised how quiet it was under the hood after I changed my idler and tensioner pulleys. I didin't think they were making much noise, but with the new ones on there is a night and day difference (mine weren't "chirping" though).
