Engine Combo?
  • Thread starter Thread starter MikeROD16
  • Start date Start date Feb 23, 2008
MikeROD16
Miami, FL
Feb 23, 2008
  • Feb 23, 2008
Any advice on what i should buy to pair up with my 65mm Throttle Body, Cobra Intake (from an explorer)?
mazroth
56
KY
Feb 23, 2008
  • Feb 23, 2008
Cylinder heads from afr, trickflow, or edelbrock. Also get the lower intake ported and matched to the heads while its apart. Alot you could do, are those the only two aftermarket parts you have?
MikeROD16
Miami, FL
Feb 23, 2008
  • Feb 23, 2008
actually no its not. i also have 1.7 RR and soon getting GT-40 heads real cheap. lol and i wish i could get those AFR heads. wow. that would be like a dream come true. but fro now, im happy with the heads im getting.
57fairlane
560
Oakwood, GA
Feb 24, 2008
  • Feb 24, 2008
you could run something like a TFS stage 1 with those 1.7s and ride out.
I wouldn't buy a new cam unless it was a custom . . . I just sold my stage 1 for $85 a couple of weeks ago on EBAY fyi.
midlife89
91
youngstown,oh
Feb 24, 2008
  • Feb 24, 2008
If your getting the heads cheap,you might want to send them out to Thumper or someone to get them freshened up.Myself,I would keep the stock cam,unless your getting a gear too.I liked the stock cam with 1.7 RR in my car.sometimes I wish I still had it in.
85Vertible
41
  • Feb 24, 2008
Thumper Heads
TFS-1 Cam
mazroth
56
KY
Feb 24, 2008
  • Feb 24, 2008
Stock cam with 1.7s should be fun. Are they P heads or reg 3 bar gt40s? P heads can be had for real cheap, gt40s normally are 100-200 more. Performance wise, I think the P heads are better. But both are good. Just many frown upon having to use different headers with the P heads.
EDC
342
63
58
In the new shop... 24/7
Feb 24, 2008
  • Feb 24, 2008
Get the GT40 heads stripped down and checked at a "quality" machine shop. Most times a properly done, multi-angle valve job done on a Serdi machine will get you some good gains. If the guides are tired, pick up some replacement one-piece stainless valves and bronze line the guides for an exact fit. I would suggest some PAC Racing 1218 beehive springs with matching retainers and locks and then toss in a small Comp 260 type grind in there. See if Tom Moss has a ported lower available and be sure you have it tuned perfectly. Bet it would run some decent numbers at the track and still look and sound stock!
Ed
BooWFO
991
Louisville, KY
Feb 24, 2008
  • Feb 24, 2008
I'd swap a cam in while you got the heads off. I'm running a e303 and like it, only other one I'd want is a tfs stg1 and not worth the $ to switch IMO.
FYI if it's gt40p's the summit shorty headers clear You will porlly want ot go with angle boot plug wires though.
MikeROD16
Miami, FL
Feb 24, 2008
#10
  • Feb 24, 2008
  • #10
i have no clue. im getting them from a explorer also. its a bang for my buck considering i dont have much money. im gonna do a 3 angle valve job and possibly shave them. im not too sure about the shaving cuz of the 1.7s.
mazroth
56
KY
Feb 24, 2008
#11
  • Feb 24, 2008
  • #11
What year explorer? 3 bars on the end of the head are gt40s, 4 bars are P heads.
96 have gt40 heads, maybe some 97 do, but most 97 and up have the P heads.
MikeROD16
Miami, FL
Feb 24, 2008
#12
  • Feb 24, 2008
  • #12
ohh ok. well all this has been a big undecisive thing due to money. but i think im gonna work on my stock heads and put on harder springs etc. and when i save up soem more, ill buy better quality heads. thats of course when i get a job, sadly im 16
mazroth
56
KY
Feb 24, 2008
#13
  • Feb 24, 2008
  • #13
Can still have a fun car with stock ported heads till you can save up some $. If your lucky, can usually find them cheap as well. A guy here locally just put some self ported Ps on his car this past year I think, hes running low 12s on them, and had run 12.6 or so on his ported E7s, think he was selling them for 100-150 bucks a few months back.
mazroth
56
KY
Feb 24, 2008
#14
  • Feb 24, 2008
  • #14
Just saw you were in FL. Im not for sure, but believe Thumper is in that area. He does alot of port work on E7 heads.
MikeROD16
Miami, FL
Feb 25, 2008
#15
  • Feb 25, 2008
  • #15
awesome, ill look into it. if anything i know a machine shop thats pretty well known locally and charges real cheap. thanks for all the help. i really appreciate it. if anymore ideas or tips come to mind, just tell me http://forums.stangnet.com/images/smilies/biggrin.gif
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
