Engine Detailing
98_stang_guy
121
Wisconsin
today is the day i decided my engine was way too dirty to be somewhat proud of. i started to clean things up a bit, any tips or anything on detailing an engine? any things that really make the engine look nice? if you have detailed out your engine (especially if its a V6), please post a picture of it, thanks!
Purple power is good too. Just make sure you water it down right away whenever you spray because it's really strong. Also use a firm brush on stuff like the intake manifold. Use vinyl/rubber cleaner on hoses and plastic. Don't wet the belt, battery, or fusebox.
Here is a quote from simple green about using it on aluminum.
Aluminum - Is it safe to use Simple Green on aluminum?
Simple Green products have been successfully and safely used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: Aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green or Crystal Simple Green can accelerate the corrosion process. Therefore, contact times of All-Purpose Simple Green and Crystal Simple Green with unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green/Crystal Simple Green residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
For engine cleaning I found 303 industrial cleaner works GREAT.
Please read about itHERE
It safe AND cleans in one application!!
I Use a two can spray system. The first can degreases and cleans (safe to spray all over the engine bay) the second can details it and makes it shine like crazy. When I call my wife Laer I'll ask her what it is. ( I am in Bugaria now doing Army stuff). But this stuff is great. about $6-7 a set.
