since we are on the topic of tables
spark controle
to gain controle of the spark curve, you want to for the most part mess with the top 2-3 row's (across) in the base timing alt timing table. This will be your WOT spark. No more need to have high timing in areas you dont really need it.
there are 2 ways to gain controle of the spark tables on our eecs from what I have seen others do.
1. set the MBT table, Altitude table, and borderline table to 55 in all cells, then use the base table as your timing settings.
2. set the MBT table, borderline table to 55's in all cells but make the top 2-3 row's (across) in the base and alt. tables match.
log after setting your timing to what you want (rec. to start low and slowly go up) and check the load and timing to see if at that load your getting what timing you were commanding.
Another tip is to N/A have all your timing in (at full advance, or have your highest timing setting) around 2,500rpm. so 1500rpm you have 16*, then 2000rpm you have 18* then 2500rpm you have 30* as an example.
Now for fuel the same kinda aplies that you want to really only mess with the WOT areas (check with a W/B to make sure at this point and take out timing when messing with fuel to be safe). Us 94-95-ers use the Base_fuel_OL. If your maf is correct and your injectors are also setup correctly you should see the WB matching your commanded.
