ENGINE EXPERTS, I NEED YOUR HELP!
crushnut
870
Oregon
Ok here it goes......
I have had a pretty loud knocking sound coming from my engine for a while, so i decided to tear it all apart to try and find the cause of the noise. While it was my original thought that i had a loose wrist pin on the #4 cylinder, i come to find out that isnt the case. :bang: So now im kinda stumpted on what was causing the god awful noise. Im taking the pistons and rods to a local machine shop to have them checked out, but i am in need of someone who knows more about engines, and this kinda thing. Please help me if you can, and thank you. :)
D.Hearne said:
I'd need to see the parts to tell you for sure what was causing the knock. Small blocks used to get a knock from the fuel pump lever under certain conditions.
Thats what my mechanic said about the fuel pump lever, and he advised me to take out the fuel pump and run the engine on the fuel in the carb, which i did and the knock/noise was still there. :scratch: :shrug:
there could have possibly been a small leak from the axuahst. My exhaust manifolds were junk and air came out of them making a horrible tick. It sounds as if you ruled it out though but I figured I would throw in my 2 cents. good luck figuring it out man.
:D Its more than a slight ticking, more like a loud awful knocking and clattering noise, similar to a diesel truck :notnice: :nonono:
Im taking the pistons and rods to a local machine shop on Monday to get them check out, do you think they could tell piston slap by just looking at the pistons i bring into them? How much do you think it would cost to just get the cylinders bored out to the next oversize, if i do all the rest of the installation myself :shrug:
69PaleHorse said:
What transmission do you have? If you have an automatic, you may want to check the condition of your flywheel. They can sometimes make a loud metal to metal knocking/clanging noise when they crack...
Yes i have a C4, i did check the bolts too see if they had come loose and while doing that i didnt see any cracks. I wish that was the case :rolleyes:
UPDATE!
I took the pistons and rods to the machine shop to have them looked over, and guess what? They showed me 6 or 7 hairline cracks in the piston skirts and at least 1 or 2 that had serious cracks in them. (so much you could grab it and flex the crack! :shock: ) Both my dad and i looked over the pistons and we didnt even see them, but the guy saw it within 5 seconds of picking up the first piston. I guess i just dont have the trained eye for that kind of thing like they do :doh:
Looks like it is time for a complete rebuild :notnice:
