Engine Falls Flat at 4500RPM
  • Thread starter Thread starter hoffwillownyou
  • Start date Start date Dec 3, 2007
H
hoffwillownyou
  • Dec 3, 2007
89 5.0- Installed an Optima red-top today, didn't realize the negative post was touching the underside of the closed hood after it was running for several minutes. Fixed the battery height but now the car seems to fall flat at 4500rpm. The engine gets pretty rough and doesnt pull like normal from there. Maybe the battery incident is a coincidence I don't believe in coincidences. Any ideas what to start checking?
jake2582
107
tallapoosa
Dec 3, 2007
  • Dec 3, 2007
the hood is grounded anyway so what would it matter?
H
hoffwillownyou
  • Dec 3, 2007
What matters is the car is running like ***** now. And when it was touching it smelled like it was burning right through the hood liner, which was pierced down to the metal by the battery connector. Like I said, maybe a coincidence. Nontheless, it has running issues now.
PUNISHER RACING
1,124
FORD CITY, PA.
Dec 3, 2007
  • Dec 3, 2007
you might of fried sumthin lectric, pull some codes on it
Bottomlesspit
I started the longest tech thread in the known uni
2,636
Del Rio, TX
Dec 5, 2007
  • Dec 5, 2007
Just an idea....I had a similar issue on my 93 yrs ago.
What happens if you increase your speed using less than full throttle? Like hold the accelerator down about 1/2 way or so and just keep accelerating. Let the RPMs increase up to and above 4500...how does it act?
We scratched our heads for weeks trying to figure mine out. It ended up being a faulty TFI module of all things.
Try to get as much evidence as you can...run the codes, experiment with different conditions, etc. It is so easy to start throwing part and money at it (like I did!).
Good luck and let us know how it's going.
Ken
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
New Engine Oil Problem
  • BubbaG
  • Aug 7, 2022
  • Other Auto Tech
Other Auto Tech Aug 7, 2022
BubbaG
J
Electrical No crank no dash no nothing, troubleshooting leads to more questions
  • Jojam99
  • Jun 2, 2022
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech Jun 2, 2022
Jojam99
J
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
'88 GT Convertible - Croatia, Europe
  • snovak
  • Oct 9, 2020
  • 23 24 25
51K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
snovak
