ENGINE FLYWHEEL and CLUTCH general ????
Salvatore007
9
:flag:
How do I know which flywheel and clutch size i can purchase????
Here is the engine i'm interested in:
Patriot Performance 3473 Patriot Performance SB-Ford 347ci / 425HP Engine
Here is the flywheel i'm interested in:
Hays 12-540 Hays Performance Flywheels
Billet Steel 157-Tooth Flywheel
1981-93 Ford 302
Fits 10.5" pressure plate
28 lbs
Here's the Clutch I'm interested in:
Ram Clutches 98794HD RAM Mustang Clutches
Powergrip HD Clutch Kit
1986-00 Mustang 4.6, 5.0L
10.5'' x 1-1/16'' - 10 Spline
and my tranny:
Ford Racing M-7003-R58W Ford Racing Tremec 5-Speed Transmission
Tremec 500 HD 5-Speed Transmission
10-Spline Input Shaft
31-Spline Output Shaft
Second, where can i i find a clutch fork and flywheel bolts that would fit this setup???
Thank You all!!!!! Semper Paratus
:flag:
Hey Sal,
Good choice on the trans. It has the 10 spline input shaft, which will fit that flywheel and clutch combination. Clutch is 10 spline, and the 157 tooth flywheel fits with stock starters (as far as i know). You want a 10.5" clutch.
You can purchase any FRPP fork and flywheel bolts to fit. Should bolt right up. Don't forget the blue loctite. :flag:
