Engine Guru's Strut Your Stuff
I need real help. I have a brand new z363 boss short block with 200 miles on it. I have AFR 185's (1 year old) with 1.72 scorpion rocker,x303 cam,and new trick flow R series upper and lower intake. Today was the first day that I notices it smoked at low rpm's just for a couple of seconds then stopped and then did it again about 20 mins later. I do have a burn off hose from the valve cover to header collector. Also smoked very heavy after setting for 3 hrs ,again just for a couple of seconds.
Check your valve seals, see if they are pushed up to the top of the valve. #2) while you have the valve cover off look at the oil return holes running through the head to the block, with a flash light shine down the oil hole to see if you can see the head gasket overlapping the hole. Which in turn will restrict the oil flow and will back up in the head and can have drainage along the valve and leak into the cylinder creating smoke which you are experiencing.
