GTOReturns said:25th no punn intended. But I hear it all the time. My stock bottom end.... If its stock or its bullet proof does it matter? I mean the bottom end doesnt make any HP, it just supports it!
85_SS_302_Coupe said:LOL like i said, vs. 1) either the stock carb setup or stock EFI setup, 2) the way Ford rated their engines back then, and 3) when you combine a Wieand Stealth intake with a good running 4 barrel, yeah i'm sure you could pick up 53hp at the flywheel when you take into account those details. The numbers they show are at higher RPMs as well. I don't really think 53hp at the flywheel for those two items are a big deal at allI'm sure they also bumped the timing and adjusted the curve and tuned the carb too.
I dont consider the cam bottom end.85_SS_302_Coupe said:A light weight bottom end could aid in HP production. Also, when you say stock bottom end i assume that it has stock pistons and cam, so to me that tells me that all the cam specs are stock and that the compression will be at least close to stock aside from whatever increase that the aftermarket heads might provide.
But lots of people make mistakes when building engines, they put on high volume oil pumps which basically robs the engine of power when you only really need that if you're running an oil cooler or looser gaps on the crank... huge oil pans also don't help, too much oil can also rob power...Boss 351 said:too much oil... from what I've read puting 5 quarts instead of 7 yielded more power at the dyno but this is the type of guy who would write 2 pages on how to save 1.5hp lol
I'd take a 360 anyday over a 340. 340's were slugs! Even the AAR Cudas!thumper460 said:the 340 and 360 Cry were the first to do this, if the pin is off center it will leave the piston at dwell longer and increase piston speed...and all that is HP !! tricks the engine into thinkling there is a long rod!! the 360 guys used to brag 20-25 HP!!
Just me..............................
Thumper
