Engine install questions
  • Thread starter Thread starter EXTRPR50
  • Start date Start date Jul 20, 2004
EXTRPR50
370
  • Jul 20, 2004
I have a '84 GT that that needs a transplant. My donor is a '90 5.0.
A couple of questions
Is there any mod you would do while the new engine is on the ground? For ease of installation of anything. I think I'll do a cam swap, but is there anything else?
In you guys opinion, is it easier to take out the engine and tranny at the same time for the swap or just the engine?
Thanx for your thoughts.
5ive.oh
195
Rocky Mountain House, AB
Jul 20, 2004
  • Jul 20, 2004
Any mods will be easier to install on an engine stand. The best would be to clean the engine up real good and repaint it, but a cam swap will be way easier with the engine out for sure.
W
wisconsinboy
78
eau claire wisconsin
Jul 20, 2004
  • Jul 20, 2004
spark plugs on a simpelar note.
mustangsquared
828
new bern nc
Jul 20, 2004
  • Jul 20, 2004
replace the water pump...good insurance while it is easy to do.
oil pump/pan(7qt)
windage tray
main support
intake
new thermastat
all the little things that could go bad in a few months...just an idea
mustangsquared
828
new bern nc
Jul 20, 2004
  • Jul 20, 2004
oops forgot to ask if 5 sp...
clutch
rear seal
steel flywheel (lighter then cast iron=faster revs)
poly motor mounts/trans mounts
V
v8only
2,378
22
49
Jul 21, 2004
  • Jul 21, 2004
pilot bearing, rear main, oil pan gasket, (get the frpp one piece) valve cover gaskets (again, frpp one piece)
install the engine and tranny as one unit, otherwise you're gonna create a lot more work. use a leveler to get it done. It only costs a few $ from harbor freight.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
