Engine light gremlin....
Lynkx
371
Vancouver Island BC
New flowmasters. while installing we cut a set of cats, and installed 2 new O sensors.
Now it ran fine, all good.
I just got my heatercore fixed today, and the engine light is on.
So i checked fluid level, and right now oil is really high for some reason??? When the car cools, the oil goes down to normal.
After being ran it still rises back up. (i might be just paranoid since the light is on.) Common sense tells me when i check oil right after its shut off after running for 5 mins the oil is high just from the engine sloshing it around
Checked all caps, listened for odd noises. car runs smooth, nice.. so my guess is the cats being cut confused the computer.
Any idea's?
Last thing im going to do is just pop the engine cap and check for air in the system for some odd reason, and after that pull off the battery cables and wait a few minutes for the computer to reset itself.
Hope nothing pops up during the drive from sooke to cobble hill. Thanks for replies.
Fiqured as much, i just didn't understand why it did it AFTER the heatercore was installed.
But on the same token, the mechanic did disconnect the battery.... since my clocks were all reset, so i don't really know if that'll fix it, but ill try tomorrow in the morning.
Nope, didn't help.. i disconnected it for 30 minutes, and i've driven the car a few hours now total highway time since heatercore was installed...
No idea anymore, sender dead?... and other ideas guys? thanks.
well, i got 2 cats left to cut... ill do that when i get a good pair of headers...
This light is making me paranoid :) im gonna bitch at the mechanic who did my heatercore, he forgot to reconnect the anttenne also.
Check the plug on the Mass Air...Had a loose plug that gave me fits with the check engine light, had to tie-wrap it in...If the mech. was fumbleing around under the hood he might have bumped it...
Re-check the connection on the O2 sensors too....
NeQX said:
Pop that check engine light out, it's annoying :) specially if you have no cats.
I hate to jump in on the thread with a question...
But how do you remove the check engine light? Would I have to remove the cluster and remove the bulb?
I am running into the same problem. The light will not go away. Even whan I disconnect the battery to clear the codes. Once I start the car up it's on. It doesn't go away at all. No matter what.
Pull the codes and fix the problem, you car will run better. Some codes cause the computer to switch to limp mode which causes uses fixed values to run the engine. The car's performance will decrease in limp mode and gas mileage will also go down.
Anyone who tells you to ignore the codes is lacking in education on what the computer does and why it does it. Maybe they should stick to working on carb'd cars instead of SEFI cars.
Here's a book that will get you started with how the Ford electronic engine control or "computer" works.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by James Probst :ISBN 0-8376-0301-3.
It's about $20 from Borders.com see http://www.amazon.com/ . Select boo...very good, and I found it to be very helpful.
do the same as these guys are telling you. Find out what is wrong.. your car might not be proforming as it should be.
The wiring Harness for the injectors and egr is getting minimum voltage and needs to be checked or replaced. I found that out and thats what pulling the codes and the engine light is going on.
No good. :notnice:
No good. :notnice:
There are two 10 pin connectors at the back of the upper manifold, one of them has all 8 injector connections. Pull them apart and check for damage. Clean the connector pins and sockets with electrical contact cleaner or non-inflammable brake parts cleaner (same stuff as electrical cleaner in a bigger can). Scrape the pins with an exacto knife and use a jeweler's screwdriver to scrape the inside of the pins. One of the pins is the +12 volt supply to the injectors.
Remember that the computer supplies a ground path for the injectors. The power for the injectors comes through the ECC relay located on top of the computer. They have power to them any time the ignition is on. The computer turns on the ground and completes the circuit, making the injectors fire. Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on. No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold)
PULL THE LIGHT BULB OUT!!!!
I did it and have had no worries yet. I have three major systems I watch: Temp, Charge and Oil pressure. If you got them screw everything else!!!!!!!!
To pull the bulb, Take out the cluster, unscrew the bulb, replace the cluster! Simple..
Nah dude, thats a redneck answer and you should be ashamed!
Besdies, im not one to run away from a challenge or cheat.
this beast, its getting fixed. However, took it to the mechanic who did the job, he didn't pull any wires, just balanced the dash just enough so he didn't have to.. the only thing we could think of was the sender unit, and its fine.
Last resort until i fiqure out some idea's is a simple oil change, maybe the filter is blocked? car is running just fine, been driving it for a week, no problems.
Try as we may, you just can't educate some people... :bang:
I guess he doesn't understand the concept of Limp mode and the reduced performace it brings.
