- Feb 16, 2008
- 17
- 0
- 0
i have a 90 5.0 5 speed (originaly an automatic) with an F303 cam, explorer intake, stock heads (shaved .030) new valve job and springs, egr delete kit, smog pump deleted, A/C & power steering deleted, all vac ports plugged except fuel pressure reg & brake booster. summit long tube headers, ORH pipe W/ flowmasters, base timing set at 17 degrees. New plugs, wire, cap & rotor. I checked for vac leaks with engine running with starting fluid & found nothing. No check eng light while driving but checked for codes any way. 11 came up in KOEO. 12 94 44 33 in KOER. after that I did the cyl balance test & got 9 (system ok). The eng dosent want to stay running by its self until it warms up a bit. while driving for example, once i shift into second and start to accelerate slowly, it will studder. give a litlle more throttle & it might back fire a couple times. a little more throttle and it starts to smoth out around 2000 RPM. i dont think this is related to the new F303 cam because the car was doing this before also. any other helpful hints would be great. thanks
