  • SN95 4.6L Mustang Tech
engine overhearing, fan not coming on...HELP!
  • Thread starter Thread starter 98stangv8
  • Start date Start date Nov 5, 2005
First Prev 2 of 2
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Nov 6, 2005
#21
  • Nov 6, 2005
  • #21
You have two...one right by the thermostat housing on the intake and the other in the same position on the other side of the intake.
98stangv8
1,036
fayetteville, nc
Nov 7, 2005
#22
  • Nov 7, 2005
  • #22
you guys are awesome! I tested the ohms (just went to wal mart and bought a meter), mine were around 45k cold, 2.5k warm...but when I tried getting the engine hot, the fan came on...so somewhere in all these tests, something must have been loose...and it is now working. thanks guys, you rock!
CanadaStang
2,093
Mb
Nov 7, 2005
#23
  • Nov 7, 2005
  • #23
Good to hear!! Might not be a bad idea to wriggle the wires and connectors around when the fan's running just to make sure it's not going to quit on you again. It could be the connection to the temp sensor that tells the computer when to turn on the fan [the one you tested] but after you had it off and on again it may be connecting better and will keep working, but if the wires are sloppy in the connector it may stop again, so just double check to be safe.
First Prev 2 of 2
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Saturday at 12:08 PM
jacekk
J
Engine Which fan clutch ?
  • AnthonyA1234
  • Jun 22, 2026
Fox 5.0 Mustang Tech Sep 19, 2026
Mustang5L5
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
