engine problems
  • Thread starter Thread starter cheshireccat
  • Start date Start date Jul 17, 2004
C
cheshireccat
Banned
Jan 11, 2004
15
San Diego, Ca
Jul 17, 2004
  • Jul 17, 2004
I'm selling my old engine, anyone know what these symptoms would mean?
loss of power above 3000 RPM with loud knocking sound.
0-60 in 3 minutes
smoke billowing from tailpipe (started long after loss of power)
idle sounds great, only problems above 3000 rpm
metal shavings in the oil
mechanic said it wasn't firing on 3 cylinders and that the rods disconnected from the pistons. he said it happens when you drive long periods of time (6hours) over 60 miles an hour on a 3 speed trany. Is this true? is there a danger of hurting the car? That sounded kinda stupid but he said he did the timing, and he tried changing wires, plugs, cap and rotor and it won't help, he said the engine is dead.
any ideas?
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Jul 17, 2004
  • Jul 17, 2004
sounds like it needs a rebuild.
T
TT670
360
9
28
Jul 17, 2004
  • Jul 17, 2004
sounds dead to me, but driving it over 60 with a 3 speed has nothing to do with it. Any mechanic that makes a statement like that and would even try changing wires and doing a tune up on a motor that makes a loud knocking noise, and has shavings in the oil needs to find another profession. And you my friend need to find another mechanic.
bull999999
112
  • Jul 17, 2004
I agree with TT670. The mechanic should've done a compression test (which should've shown no compression on those 3 cylinders) before doing a tune up on a motor like that.
D
D.Hearne
11,730
south louisiana
Jul 18, 2004
  • Jul 18, 2004
I also agree with the others, that "mechanic" is an idiot. Rods disconnected from the pistons? Nooooooooooo. Broken rods? possibly. spun bearings? possibly. Bearings worn completely out? Most likely. Time for it to be rebuilt, or pulled out , dis-assembled to see if it CAN be rebuilt. If it's in that bad a condition, you probably need to be looking for another motor to swap in, or one that's in better condition to be rebuilt.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Need help and Advise - 89 Problem Child
  • Sheela
  • Oct 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2025
evintho
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
J
Car Diagnosis
  • j.2016
  • Aug 31, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 31, 2025
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
