Engine Quits With AC on and clutch in
Sompin2do
59
TX
94 GT 5.0
Recently had AC fixed and now my car will die when I have the AC on and put the clutch in. It only happens when it's real hot outside, usually 90+. At this point the shop that did the work can't duplicate so the next time it happens I'll take it in right away. I was just wondering if anyone has history with this.
Thanks
Mike
Sompin2do said:
94 GT 5.0
Thanks
Mike
Sounds like the iac might be not allowing air to flow through it as it should.
Might try giving it a good cleaning with some kind of solvent.
Grady
Grady as usual, is right-on. It might also take a little goosing of the throttle stop to get the revs up a little.
Good luck.
The shop got nothing on the codes. Okay, I'm really not stupid, but what is IAC? Sounds like you guys are on to something :hail2: and since it's going to hit 96 up here today I'm betting this will happen again. I'm in the DFW area.
Mike
