Engine Rebuild
Elgrano
30
Hi guys...
I am thinking on rebuilding my 98' engine...can anyone list all the parts I need to get and a brief descrition of the work that has to be done in order to make that old eninge like new again...Thanks!
'98? I think you either have a typo or posted in the wrong section. If it's a 4.6 post in 4.6tech, you'll get more responses. I guess alot of the things would be the same, but there are also probably alot of things that are different between a 4.6 and a 5.0. Especially with the over-head cams.
The most common things are bearings (main, rod, and/or cam), gaskets, and a honing of the cylinder walls. But everything depends on the condition of your engine. If it is a 5.0 list more specifics about it.
