engine rebuild
  • Thread starter Thread starter 2fast4u770
  • Start date Start date Jan 16, 2011
  • 3
  • 6
1 of 6 Next Last
2fast4u770
121
12
28
Jan 16, 2011
  • Jan 16, 2011
looking to build a engine for a 89 mustang im about to buy.need help tho, whats better between a 306 or 347 stroker and what transmission would match up best.i dnt want a race car but i do want alot of power. if you have anymore advise to get me please do..
stykthyn
5,232
2,652
223
gainesville
Jan 16, 2011
  • Jan 16, 2011
If you aren't racing just go with a fresh 306.
1bad67sbf
674
N. VA
Jan 16, 2011
  • Jan 16, 2011
a good 306 will work fine and build it for forced induction to give you the (lots of power) your looking for
2fast4u770
121
12
28
Jan 16, 2011
  • Jan 16, 2011
and transmission will be best with a 306
1bad67sbf
674
N. VA
Jan 16, 2011
  • Jan 16, 2011
do you like to shift or just drive?
2fast4u770
121
12
28
Jan 16, 2011
  • Jan 16, 2011
shift, 5 speed
1bad67sbf
674
N. VA
Jan 16, 2011
  • Jan 16, 2011
t-5 sounds like an easy answer.get one rebuilt or get one used and have it rebuilt. (your choice)
2fast4u770
121
12
28
Jan 16, 2011
  • Jan 16, 2011
would that be cheaper than getting a new one, and whats a good website to get a 306 short block
1bad67sbf
674
N. VA
Jan 16, 2011
  • Jan 16, 2011
yes rebuilt should be cheaper and here is just one of thousands of options
Ford 306 Performance Short Block - TREperformance.com
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jan 16, 2011
#10
  • Jan 16, 2011
  • #10
The cost difference between a 306 and a 347 is so small that you'd really be doing yourself a disservice by not building a 347. Once you go beyond just a quick hone and re-ring and get into boring a block, you're looking at a decent amount of money in machine work, new pistons, balancing, etc. Once it's all said and done, you could have spent another couple hundred bucks and had 41 more CI. Which, IMHO, is a no brainer.
1bad67sbf
674
N. VA
Jan 16, 2011
#11
  • Jan 16, 2011
  • #11
347's are nice also but when someone tells me they dont want a race car it sounds like someone who wants low maintanace and i dont know if a 347 stroker fits that very well. i could be wrong but a stockish 302 (306) block is good for 100k+ if taken care of. what is the average rebuild or replace done on a 347? can they be rebuilt after? i ask because i have thought about it myself.
robo
132
cleveland ohio
Jan 16, 2011
#12
  • Jan 16, 2011
  • #12
i'd build the 347. i like torque, especially on the street at relatively low rpms. (not advocating street racing just good old fashioned spirited driving)
it will cost you about 1500 more though. not sure how you can do it for a few hundred over a 306. the kit will cost 900 to 1500 and you will need the block relieved for rod clearance.
whatever you do, hire a good machinist, build a relationship with him and listen to what he tells you to do.
engine lifespan is more a product of quality machine work and assembly than rod ratio or piston pin location.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jan 16, 2011
#13
  • Jan 16, 2011
  • #13
Why wouldnt a 347 be rebuildable? I have friends running 331's and 347's for over 6 years. Early 347's had the wrist pin oil problem, most kits(probe for certain) have fixed the problem and now offer offset the piston pins to help with the rod ratio problem that 347's were plagued with in the past. So for a few more bucks go bigger. Take care of your 347 like any other motor and it will last.
1bad67sbf
674
N. VA
Jan 16, 2011
#14
  • Jan 16, 2011
  • #14
how much OS is needed to run a 347 kit?
stykthyn
5,232
2,652
223
gainesville
Jan 16, 2011
#15
  • Jan 16, 2011
  • #15
I always hear people say its only a couple hundred more for a 347, but like mentioned earlier the kits run for a grand or better and then you have the H/C/I and fuel system to deal with on top of that. By the time you are done you are in 3-4 thousand on top of what a stock rebuild will cost.
My vote would go to a 306/302 with an explorer top end and tfs1 cam. The entire combo can be built and running for under 2k dollars and is an extremely stout street set up.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jan 16, 2011
#16
  • Jan 16, 2011
  • #16
OS, offset? I'm sure it would depend on the piston brand, most brands will have it listed.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jan 16, 2011
#17
  • Jan 16, 2011
  • #17
Thats because people dont stop, if he's ordering a short block he might as well spend the few hundred more and use his current parts and upgrade later. It will still make more HP and lots more torque
1bad67sbf
674
N. VA
Jan 16, 2011
#18
  • Jan 16, 2011
  • #18
no oversize piston. is it .30 .40 over stock?
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jan 16, 2011
#19
  • Jan 16, 2011
  • #19
Ah, most 347 kits offer a STD, .30 and .40 piston
stykthyn
5,232
2,652
223
gainesville
Jan 16, 2011
#20
  • Jan 16, 2011
  • #20
I just see no point in building a 250hp 347 when you can get the same numbers with stockish parts.
  • 3
  • 6
1 of 6 Next Last
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
G
Fox engine swaps
  • Gravity
  • Aug 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 12, 2025
2000xp8
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
