engine rebuild
  • Thread starter Thread starter 2fast4u770
  • Start date Start date Jan 16, 2011
  • 3
  • 4
  • 5
  • 6
First Prev 5 of 6 Next Last
J
jp39299
#81
  • Jan 22, 2011
  • #81
I am in his same predicament. I went with a 331, over the 347 or 306. I started just wanting a fresh 302-found out it needed to be bored.
wanted to definitely get better hardware, since its the weak point of the smf.
arp rod bolts = $70 , recondition the rods = 230
then I still had to drop more $$ for polish (50.) or cut crank(175.) , bearings (main/rod/cam) and rings.
press off and press on new pistons (50.)
hot tank, balance assembly, align hone and square the block. and rebuild short block
I am into the machine shop for 1200 for labor.
NEW scat/eagle rods w.3/8 arp bolts = 190.
New .30 flat tops I couldn't find a set for under 400.
crank 50 or 175. plus bearings and rings equals roughly 800/900 bucks
I bought the 331 kit for 1050.
no brainer here 25 extra cubes for 100. bucks - priceless!
Boosted92LX
5,721
4,244
224
Jan 22, 2011
#82
  • Jan 22, 2011
  • #82
1bad67sbf said:
no, i dont have a lot of money to build my dream motor yet like some of us do, so i do what i can with what i got. mine for my 67 should be 375ish flywheel hp with a stock .40 over bottom and a 600cfm carb, an old school f4b intake, comp hydro tappet .512 lift cam and edelbrock 1.90 1.60 e street heads and some supporting mods. seems like most people get a fair cam and some gt40 heads and an intake and say its bad ass but most often puts alot less power down than the thought they had.
From what I've seen It's hard to break 375 ish n/a with a 600 carb and 10:1 c/r out of a 302. You can do more with more compression, a lot more, but it's bye bye pump gas. That's why, like I said earlier I started leaning toward more cubes 20 years ago. On spike tv a year or so back, on their horsepower tv program they did an edelbrock combo on a 347 with edelbrock heads, cam, intake and carb all matched and it dynoed something like 480 hp and 500lbs torque with 10:1 cr on 93 octane gas. In my honest and humble opinion, that's better than boost, but everybody's entitled to their own opinion!
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jan 22, 2011
#83
  • Jan 22, 2011
  • #83
That's probably because the carb is on the small side, and probably also assuming a weak two plane manifold and small heads.
Not that you should put a lot of faith in magazine articles, but I've got a recent MM&FF issue where they made 412hp from a 306 with 10:1 CR, Twisted Wedge 185 CNC heads, an OTS Comp cam and some junk ProComp dual plane manifold. I forget what size the carb was, but it was bigger than 600. Same engine with a GOOD single plane manifold and a custom cam with more lift (the cam they used only had something like .550-.560 I and E, but the heads come assembled with springs that will handle .600), and I'm sure they could have easily seen 430 or better, and this would have been a very streetable engine, too.
Boosted92LX
5,721
4,244
224
Jan 22, 2011
#84
  • Jan 22, 2011
  • #84
sure. twisted wdge heads are waaay better than the edelbrocks, and 412 is totally believable. I have a friend doing that with afr's. I agree with you. my point is you won't see 500ish hp with a 306 and you can easily with a 347 or stroked 351. It's silly to me to spend 3k to 5k for a power adder to make 400hp when you can put that money into the ENGINE and do the same, then later spray it or boost it a little if you need more. oh, and 600 holleys are for people who aren't serious about going fast!
Boosted92LX
5,721
4,244
224
Jan 22, 2011
#85
  • Jan 22, 2011
  • #85
check this guy out- 408w with 150 shot runnin 9's
YouTube - 20100102001647.mpg
YouTube - 9 sec mustang
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jan 22, 2011
#86
  • Jan 22, 2011
  • #86
wOW this thread makes my brain itch, alotta of mixed up ****ty info here.....
SSeater said:
and I had my m&h racemaster slicks on that day. I sprayed it out of the hole. he about **** when I did a wheel stand and ran off and left him. That car ALWAYS tried to swap ends. it was like a never ending power slide.
Wait wait waitttttt.... Your saying the car was always in a never ending power slide, but you pulled the wheels off the ground on an unprepped street without warming up the tires even.... Is your name Dominic Toretto?
1bad67sbf
674
N. VA
Jan 22, 2011
#87
  • Jan 22, 2011
  • #87
yeah that is about all i will get from MY SETUP but i just tried to get alot of my bolt on parts this build and when it gets some wear i will change that STOCK bottom end . it was just an intake and carb on the motor to start with. so this will be a nice bump in power then in a few years i will go to level 2 with my build and put a stroker in it. when i do that i will have to get a bigger carb but a 600cfm is all that most 302's need without a stroker kit in them.
Calculate Required CFM Of Carburetor
i just like boost because i have had cars with turbo and it is soooo much fun.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jan 22, 2011
#88
  • Jan 22, 2011
  • #88
yup, saw him driving too
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jan 22, 2011
#89
  • Jan 22, 2011
  • #89
lol i was gonna post that picture
ViperPunk
195
idaho
Jan 22, 2011
#90
  • Jan 22, 2011
  • #90
haha that is awesome!
Boosted92LX
5,721
4,244
224
Jan 22, 2011
#91
  • Jan 22, 2011
  • #91
LOL! yeah I know. sorry, I'll clear that up. I had a set of bfg's I would drive around on in town and they were the powerslide tires. Old t/a 295/50/15's
see them in this thread:
http://www.stangnet.com/mustang-forums/830497-back-day.html
And I had a set of m&h's that bit like a pissed off dog. I happened to have them on when the guy on the bike pulled up. They were allready pretty warm from previous stoplight assery.
I know sounds like b.s. but it's the truth. Vin Diesel wishes he was me!
Boosted92LX
5,721
4,244
224
Jan 22, 2011
#92
  • Jan 22, 2011
  • #92
.......and don't hate because you don't know how to do it!!!
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jan 22, 2011
#93
  • Jan 22, 2011
  • #93
there's no hate here, if you said i almost got a tire off the ground it would have been a little believable. But your not gonna pull the wheels on an unprepped street.
Boosted92LX
5,721
4,244
224
Jan 22, 2011
#94
  • Jan 22, 2011
  • #94
Whatever. Have you seen the street? No, you haven't. The guy on the bike told me I did it. His name is Ed. would you like his phone number? Go bother someone else.
stykthyn
5,232
2,652
223
gainesville
Jan 23, 2011
#95
  • Jan 23, 2011
  • #95
Fwiw I've seen a 2.3t full the drivers wheel in a parking lot.
Boosted92LX
5,721
4,244
224
Jan 23, 2011
#96
  • Jan 23, 2011
  • #96
I know man...
I've seen several cars pull wheels on the street. Anyone who says it isn't possible is either
A) Just trying to talk **** and start trouble...
or
B) They are a sheltered over opinionated neophyte who has never spent any time around race cars....
or
C) both....
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jan 23, 2011
#97
  • Jan 23, 2011
  • #97
Hahahaha yeah cause Jeff doesnt have a race car lol
Boosted92LX
5,721
4,244
224
Jan 23, 2011
#98
  • Jan 23, 2011
  • #98
or
D) just an ass.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jan 24, 2011
#99
  • Jan 24, 2011
  • #99
relax old man, mabye alzheimers is kicking in a little early and you are making your fish stories sound a little better
Its just a STREET car man...
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jan 24, 2011
#100
  • Jan 24, 2011
  • #100
Yeah so is mine
  • 3
  • 4
  • 5
  • 6
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
G
Fox engine swaps
  • Gravity
  • Aug 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 12, 2025
2000xp8
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
