I think I had a similar issue not to long ago when doing my T-5 swap. Is it just turning over some more after you turn it off? That's deiseling and from my experience is usually a timing issue. Is it actually cutting off and then trying to start back up? If that's the case try and change your ignition switch, it's easy to do, takes 10 minutes.
