Engine squeeks during acceleration
  • Thread starter Thread starter Fastcat
  • Start date Start date Aug 18, 2004
F
Fastcat
582
St. Louis
Aug 18, 2004
  • Aug 18, 2004
In My T-bird (89 w/ a 3.8L) after the car is all warmed up and driven for a couple of miles the engine squeeks everytime I hit the gas then it stops. It happens during all rpms but it only will squeek for a second, but it squeeks OFTEN and its driving me crazy now! I replaced my tensioner pulley and it still squeeks. Ive sprayed WD-40 on all of the accessory pullies (exept the crank) and it still squeeks. Could it be my harmonic balancer? But the engine idles run and doesnt ever shake or vibrate.....
blk92stangg
583
Hawaii
Aug 18, 2004
  • Aug 18, 2004
Well, I found that since most if not all of my Stang's pullies have sealed bearings, shooting WD40 most often will not help...if the bearing is squeeking it is likely the ball bearings inside are hashed anyway, and shooting the WD40 in may actually exacerbate the problem by thinning out the grease inside it, assuming the wd40 can even get into the bearing itself. I found that by getting a piece of thick hose, sticking one end in my ear, and putting other end close to the different pullies, you can pretty much figure out which one is making the sound. On mine, after spending 70 bucks on a billet tension pulley, it turned out to be a loose bolt on the smog pump delete mount...go figure. GL
F
Fastcat
582
St. Louis
Aug 18, 2004
  • Aug 18, 2004
even the alternator and power steering pullies have bearings?
blk92stangg
583
Hawaii
Aug 18, 2004
  • Aug 18, 2004
Yup, anything that spins on your car has bearings. The bearing sits between whatever spins, and the stationary object it is attached to (sorry bad explaination). ie your tensioner pulley and the bolt that holds it to the tensioner assembly. That bolt actually applies force to the inner race of the bearing, and pulley is pressed onto the outer surface (spinning part) of the bearing. For the alternator, the bearing is inside the housing, and is not accessible from the outside (from what i remember. When you zap off the pulley, the bearing wasn't visible). Not sure about the steering pump tho.
HISSIN50
34
129
Aug 18, 2004
  • Aug 18, 2004
im with Blk92. also, if you have aftermarket pullies, sometimes the coating (if there was one) wears off the grooved surface and can make some noise.
good luck.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Aug 18, 2004
  • Aug 18, 2004
Besides, if I were you I wouldn't be spraying WD-40 on my belts anyway. It doesn't last long for one and will degrade the rubber on the belt over time and could actually make belt squeak worse. For future use, try using a bar of soap on the belt surface instead. Works much better!
stockhatch
536
polar sloth country
Aug 18, 2004
  • Aug 18, 2004
Dude, just pull off the belt to eliminate driven accessories. Dont drive it across the state, just down the road and it will be fine. If it still makes the noise at least you know what ISNT making it. I had this problem a few years back....guess what it was? The head gasket. Yes, the headgasket. It was compression "chirping" as it leaked out of the cylinder due to a broken head bolt. I hope yours is an alternator bearing.
AC
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine Bad engine shaking at idle
  • sav22rem22
  • Jan 2, 2024
6K
Fox 5.0 Mustang Tech Feb 2, 2024
sav22rem22
M
  • mnky99
  • Sep 5, 2025
mnky99
M
