Engine Stall?
5.0Pilot
11
Oxnard, CA
I've searched on the topic, and I know this has been brought up before but...
I daily drive my 5 speed, and after driving about six miles, she starts stalling whenever its under 2k. At the light at idle she'll die completely, and I have to keep restarting her the last leg of the drive. Same scenario on the way home.
The check engine light will go on and off sporadically, but when I used the scanner tool, nothing was stored. I also went down the list of items to check (TPS, IAC, vacuum lines) but nothing has worked.
I know that this has happened to you before, so I would like to hear your story of what your specific issue was and what you did to fix it.
Thanks:D
What does that mean Mustang5L5?
I should have been more detailed. I want to add that I had the engine rebuilt 5k ago, along with replacing or swapping the IAC, TPS, air charge temp. sensor. coolant temp. sensor, ignition module on the distributor, and vacuum check valve.
25thmustang had something very simmilar way back, but I couldnt find out how he resolved his problem.
