engine swap 01 GT
hungrymonkey
White by Birth, Trash By Choice
12
108
Oregon.
Found a 2001 GT on craigslist. The guy is asking $2,000 OBO. Car has a blown engine after overheating. 115,000 on chasis and drivetrain.
I have found on CL an 03 mustang 4.6L for $1450, and a "4.6L R code" for $975.
Good deal? Too much work?
Any major engine compatability issues I need to be aware of?
fwiw, I have never worked on the 4.6L. But I am capable on the mechanical side of things. I have the space, money, time. etc.
I will be replacing my DD fox vert.
2000 sounds like a steel for that. kelly blue book averages 4-6k depending on location and engine mileage. For 3k you can get a good built bottom end and install it your self. For 5k you can have heads and cams as well. Then you'd have a fully built mustang for 7k which is one hell of a deal.
Or if your not into all that you can buy a mach1 engine which sell for 2-4k depending on mileage and do an engine swap. I'd say build the say first start with just a bottom end if that's all you can afford then do heads, cams and throw on a supercharger. Then you'll be at 500+hp instantly.
Just make sure the transmission still works, it would suck if it needs a rebuild. I have no idea how to test it or know if there is a way to test it, I guess its a gamble on that. Either way, Ive seen used ones for less than $400 on craigslist or ebay.
4.6's are easy to work on. Similar to a 5.0. Just rebuilding the pistons and so on is different. If you go to http://www.modularmustangracing.com/ you can buy a completely built bottom end saving you the headache and trouble of doing it wrong. Comes with warranty. Everything else if you've done on a 5.0 shouldnt be hard at all for you.
I would definitely get it. You can find a fully built PI engine for less then $1,000. I've even seen folks sell the engine and trans for around $1,000 to $1,500. Or you can get a 4.6 short block and swap over the top end parts for even less. Heck I bought the 4.6 that's currently in my 03 GT for $500 plus I threw in some stuff I had sitting around. Check the forums and EBAY and you can find or make some killer deals. The trans is probably still good if the car just has a blown head gasket or something but that's a roll of the dice...
Try car-part.com (search salvage yards). I found the 2004 Crown Vic Romeo motor with 35k miles for $800 that way.
That motor now rests between the frame rails of my 2000 GT. 15K miles since install. Runs great.
That motor now rests between the frame rails of my 2000 GT. 15K miles since rebuild.
this man speaks the truth. Car-part.com is a great website. There are a handful of aluminum PI explorer engines, crown vic PI engines, etc... in my area with under 100K selling for under $1,000.
