Hey,
My son just swapped his 81 I-6 over to 88 HO.
One of our last obstacles is the fuel lines for EFI.
The donor car was a Lincoln Mark, so the fuel lines are:
A: Stock
B: Ancient
C: Ill fitting
So, what I need to know is a good way to either custom make fuel lines, or modify the parts I have to fit. I need to know what rubber line is acceptable for use, what clamps, and how to keep the hard lines where they mount to the fuel pump and fuel rails.
My son is a teen, so we are on a budget. We need a good way, a simple way, a safe way... We'd like to do it the 'best' way, but that is probably expensive.
Actually, the worst part of the Mark fuel lines are the plastic sections. The steel sections fit very well, but the longer car made for long sections of plastic. Fitting into the smaller car has made for tight bends, excess line, and even some crimps trying to form in the plastic.
Can I remove all the plastic sections and replace them with rubber?
What rubber line can handle the 40ish psi of the EFI system?
What clamps will work under that pressure?
I am generally a carb guy, but I figure that I can't just throw 5/16" rubber hose on here with worm gear clamps... Or can I?
IDEAS ARE WELCOME!
THANK YOU!!
Dave
A: Stock
B: Ancient
C: Ill fitting
IDEAS ARE WELCOME!
THANK YOU!!
Dave
