Engine Swap T Bird To Stang
Techn9ne993
Hello, im new to this forum, but im hoping for opinions on hard this swap would be. I have a 1995 ford thunderbird that's totalled, and it has the 4.6 v8 engine in it. And i also have a 1995 v6 mustang. So i am wondering what the possibility of putting the 4.6 from the t-bird into the mustang is and if ill run into any major issues. Thank you!!!
Start by reading here on the V6 to v8 swap:
http://www.allfordmustangs.com/forums/v6-tech/287072-v6-v8-swap-faq-newbies-read-here-first.html
There are slight differences between the 95 and 96 4.6 modular.
Short answer is, Yes you will run into major issues. Some include:
  • This project needs a motor wiring harness from the V8 Mustang. The T-Bird harness isn't likely to work.
  • You will need a V8 Mustang K-member. The T-bird has a different design.
  • The project to convert a V6 Mustang to V8 is not trivial.
