  • 2.3L (N/A & Turbo) Tech
engine wont idle
  • Thread starter Thread starter stykthyn
  • Start date Start date Jul 11, 2006
stykthyn
5,232
2,652
223
gainesville
Jul 11, 2006
  • Jul 11, 2006
ok I bought my mustang last week and it wouldnt idle. I started by checking all the sensors and I found that when I disconnected the MAF the car would idle close to normal. Thinking there was a faulty MAF I bought a new one, but as soon as I plugged it in the car died again. What is the deal. I tried pulling the codes, but I am not very good at it the two best matches I got were faulty DIS and EGR not opening, EGR voltage too low. any ideas where to start?
2000silverbulit
31
Dublin/Walnut Creek, CA
Jul 11, 2006
  • Jul 11, 2006
the IAC ... what year stang is it?
stykthyn
5,232
2,652
223
gainesville
Jul 11, 2006
  • Jul 11, 2006
pulled it and cleaned it out with carb cleaner, may try soaking it in acetone over night, but I still dont think that is it, I should have seen an improvement from the first cleaning.
stykthyn
5,232
2,652
223
gainesville
Jul 11, 2006
  • Jul 11, 2006
oh yeah 93, has 107k on it
16vstang
100
Way up in Maine
Jul 11, 2006
  • Jul 11, 2006
Try unpluging the egr and se what happens.
stykthyn
5,232
2,652
223
gainesville
Jul 11, 2006
  • Jul 11, 2006
is is possible to delete the egr altogether? I know that my camaro ran better after I ripped that POS out.
snake109
60
Austin TX
Jul 11, 2006
  • Jul 11, 2006
i would find out where the voltage is lost in the egr circuit first
2000silverbulit
31
Jul 12, 2006
  • Jul 12, 2006
And the fact that would you imediatly fail SMOG blah blah blah... and thats not the point, it should run fine with it connected so something else is the problem.
If it runs better even for a bit with the cleaned out IAC then you know that is the problem, I had to change my IAC at 70k and havent had a problem since
if it would jump revs with the clutch in or sometimes sitting at a light it would die, esp if you tried to use accesories.. then its prob the IAC
stykthyn
5,232
2,652
223
gainesville
Jul 12, 2006
  • Jul 12, 2006
I found the problem, there was a small vacuum hose the size of a coffee stir that had come in contact with the valve cover and melted through. the was enough hose to re-route and after I reset the idle everything is golden. Thanks guys
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
W
  • Locked
Fox Wifes 1993 LX 5.0 dies after replacing ignition parts
  • Warhorse85
  • Aug 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2025
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
4K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
